New shoes!
I'll be swapping them between my current set of A6's (285/335) at next weekend's autox. We have had a few years on A6's, so I think I'll be able to feel a difference. Hope I can get enough heat into them for a fair comparison.
I tried out the new Hoosier slicks and I like it a lot.
On my first session with the slicks I was just tip toeing a bit to get used to the tires. I was immediately within range of my best times using the trusted A6 tires.
Immediately I noticed that they had great feedback to the driver so you can definitely drive these tires harder. I lost a little bit of forward bite but I thikn the setup needs to get adjusted to get it back.
They also came out with a new size which will fit better on my wheels. The 305's that I tried were a little narrower than the 315's I had and almost an inch narrower than the 335's.
Check out the video of my first few laps with the slicks.
http://www.youtube.com/watch?v=OrTxTRr5Z2E
I had the wrong gear for the track and was trying to keep the rpm's somewhat low because I still don't have a dry sump nor do I have an Accusump for the car. I still spun a bearing though on the following day
Good to hear they work decently and have good feedback. I hope I don't loose forward bite though. The rears are going to be taller than my current ones, so that should help, very close in size to the 315/345 setup I ran last year.
Awesome. Really looking forward to hearing how they do in comparison to the A6's.
Can't really tell from the pictures, but what sizes are they?
Also, what wheels will you be running them on?
Former Vendor
1 Post
Hi Gary,
They have more sizes coming out this year, but for now this is it in 18"
Tire Size - TreadWidth - Dia Approx. - Circ Recom. -Rim Measured
Rim Section
Width
250/650R18 9.1" 25.6" 80.4" 8-9.5"
265/645R18 10.1" 25.5" 80.0" 9-10"
280/680R18 10.0" 26.9" 84.6" 9-11"
285/645R18 10.9" 25.5" 80.0" 10-12"
305/645R18 11.8" 25.6" 80.6" 11-13"
320/650R18 12.0" 25.7" 80.75" 11-12"
305/30R18 VRL 11.6" 25.6" 80.5" 11-12" Viper Spec tire
315/690R18 12.3" 27.3" 85.6" 11-12"
335/30R18 VRL 12.6" 25.6" 80.5" 12-13" Viper Spec tire
310/710R18 12.4" 28.1" 88.4" 10-12"
Let me know if you need any
MSI is a Hoosier Direct Dealer
Rim Section
Width
Just wondering if you ended up doing this, and if so how they compared?
