Best autoX tires for OME Speedline wheels
Old 04-09-2009, 11:07 PM
michaelkrelina
michaelkrelina's Avatar
Default Best autoX tires for OME Speedline wheels
I have a C5Z 2003. I'm looking for the best performance using either standard wheels or four 10.5 OME rear Speedlines. I understand that Hoosiers 295/35-17 F and 315/30-18 R are commonly used. I have also seen Kumho 305/30-18 F and 315/35-18 R used (do they fit without any modifications?).
I understand that Kumhos last longer but perform slightly less well. Is that still the case when the above larger tire size is used with Kumho, would the small size difference compensate for the performance difference of the rubber?
Old 04-10-2009, 07:57 AM
Garick
Garick's Avatar
do you want to stay in any particular class?
Old 04-10-2009, 09:00 AM
LehmanZ06
LehmanZ06's Avatar
Hoosier A6.....front 295....rear 315 if you need to keep stock sizes
If you can go 18" all around.....then stock rears on back and front 295 315 rear imho
Old 04-10-2009, 09:49 AM
waktasz
waktasz's Avatar
I don't think you will notice much of a difference between the two if you are new to r-compound tires. If you are trying to get every ounce of performance from the car, the Hoosier 295/315 combo is pretty much the standard in SCCA SS class.
Old 04-10-2009, 10:53 AM
michaelkrelina
Default No particular class
I happen to have some speedline wheels which are light and inexpensive and do not force me to make modifications such as tubbing or using longer bolts or spacers. I just do local events and I am in the top class as it is in Ottawa, Canada.
Old 04-10-2009, 11:10 AM
michaelkrelina
Would you happen to know if Kumho 305/30-18 F and 315/35-18 R fit a C5 without any modifications when mounted on Speedline 10.5x18? The 315/35-18 has larger diameter than the stock tire .. any rubbing problems when the suspension compresses ? .. the car is at the low end of the height range specified by the manufacturer but has not been lowered beyond that.
Does the balance of the car change much, as compared to 295 F/315 R?
Would it be desirable to have less understeer with the bigger front tire? Or does skillful trailbreaking take care of all that?
Old 04-10-2009, 12:41 PM
sothpaw2
sothpaw2's Avatar
Are you sure 295 mm width fits on a 9.5" wide 17" rim? I thought 285mm was maximum for sidewall safety during cornering.
Old 04-10-2009, 12:47 PM
VetteDrmr
VetteDrmr's Avatar
Received 1,397 Likes on 749 Posts
If I can run 275/40/17s on 17x8.5 I think 295s would work fine on 17.9.5.
Old 04-10-2009, 01:31 PM
michaelkrelina
Default I'm sure it works
I'm sure it works, based on my reading
Old 04-11-2009, 12:22 PM
waktasz
waktasz's Avatar
295s work just fine. The Hoosiers fit even better than the Kumhos in this pic.
Old 04-11-2009, 02:46 PM
TedDBere
TedDBere's Avatar
295s on the fronts in my sig picture, fully loaded...offset 0.25 inch.
Old 04-12-2009, 02:32 AM
michaelkrelina
Default Just curious: what is the size of the Kumhos
Just curious: what is the size of the Kumhos in the picture? The telephoto takes away some of the perspective related to distance so its hard to tell what the size of the front and the back wheels/tires is.
Thanks for your input
Mike
To Best autoX tires for OME Speedline wheels
Quick Reply: Best autoX tires for OME Speedline wheels
