Diff Cooler Setup (pics)
Old 04-12-2009, 12:13 PM
NemesisC5
Support Corvetteforum!
NemesisC5's Avatar
Default Diff Cooler Setup (pics)
I finally took some pics of my diff cooler installed and decided to post up pics in case anyone else was on the fence. I replaced my diff with an upgraded unit with the C6Z fluid pump built by RPM Transmissions and purchased through my friend John Page at 21st Century Muscle Cars in Carrolton, Texas. John was one of the first to inspire me to hit the roadcourse. As we talked about mods he was doing to my supercharged street Vette he sometimes spoke of how much fun it was driving a roadcourse...anyway I purchased another Vette for the track and the rest is like you know it....HISTORY. Back on topic...below are some pics of my diff cooler setup:
Looking through C5Z rear brake duct screen
Setrab fluid cooler with Setrab bracket secured to fender liner
Stainless mesh covering vent exit & backside of fluid cooler
C6Z fluid pump on C5Z diff
"Cooled" fluid return line
Fluid lines running to Setrab unit (I'll wrap these so they don't saw on my car)
The synchros in my tranny are well worn and when I have the cash for the tranny rebuild I'll have the C6Z pump installed and run another Setrab cooler on the passenger side brake duct. Presently I am in the process of adding a Setrab cooler in series with factory C5Z PS cooler. It will be located on front bumber core support hanging just behind the C5Z front screens.
Old 04-12-2009, 02:28 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
Thanks!! Very cool!!! (no pun intended).
What kind of temp changes have you seen?
Can the C6Z/C5 diff cover-pump be purchased?
Can you give an overall cost breakdown? TIA.
joel
Old 04-12-2009, 03:04 PM
sperkins
sperkins's Avatar
Sweet.
Old 04-12-2009, 06:33 PM
NemesisC5
NemesisC5's Avatar
joel
I wish I could give you exact numbers but I have a bad memory and no receipts but I'll give it a try...
-Temp difference: my DIC occasionallly read "Transmission Temperature 279*" to "Transmission Hot"....I cannot quantify but I no longer get a DIC message
-I'm sure the parts can be purchased but I believe RPM Transmissions did some fabbing to adapt to C5 application
-I opted for the standard Stage 1 diff with 3.73 R&P with the pump being the only diff upgrade. Several respected racers, members & vendors advised that would be all that I need if I planned a seperate cooler. $1395 for the Stage 1 diff & $499 for the C6Z fluid pump installed. Links below.
http://www.rpmtransmissions.com/differentials.html
http://www.rpmtransmissions.com/differentialparts.html
-Setrab cooler is part number A13F225 cost $120.30/ea x 1
Link. http://64.202.180.37/files/setrab$.pdf
-Setrab fittings -6AN M22RU06-90 $24.15/ea x 2 (on above pdf)
-Misc. -6AN hose fittings & stainless braid hose ~ $75-85
Link. http://64.202.180.37/files/tools.pdf
-Mocal/Setrab Cooler Mount (115m) ABKT-115 $15.75/ea x 2
-Redline lightweight 90w synthetic diff lube & additive
Sorry for lack of exact details, it's been in service for a couple of events and I ran across these pics so I decided to post
Old 04-13-2009, 11:37 AM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
Thanks for the info!
I wonder how hard it is to add the C6Z diff pump to a C5 diff?
Old 04-13-2009, 01:03 PM
NemesisC5
NemesisC5's Avatar
I wish I had the answer, maybe someone will chime in. In my opinion this setup works well from a relability standpoint, also cost effective if you are in the process of doing a diff swap or upgrade (which I was).
To Diff Cooler Setup (pics)
Quick Reply: Diff Cooler Setup (pics)
