[PICS] Katech's Mosler MT900KR project
Premium Supporting Vendor
I thought you guys might like to see the progress of our Mosler MT900KR project. We basically took the MT900S street car and converted it into a track-day/HPDE machine.
Custom built LS2-based 427
Carrillo H-beam rods
Callies Magnum crankshaft
Katech pistons, just over 11:1 CR
DLC pins
GM Stage 3 cam
LS7 heads
Carbon fiber valve covers and coil relocation kit
Expected to make about 640hp.
Considering the car's light weight, awesome power, and phenomenal cornering ability, a proper dry sump system was high on our priority list. This features a custom made dry sump system with ARE pan and Dailey 3 stage scavenge pump. Internal pressure pump. The dry sump system was custom designed to fit within the space constraints of the Mosler and still retain the AC for those hot track days (the Mosler has almost no side window). Also a custom made alternator bracket to make space for the dry sump pump.
I'll post more pictures as things progress.
DLC pins
GM Stage 3 cam
LS7 heads
Beautiful. This has always been, in my opinion, the ultimate street/track car. Relatively easy to work on, lots of Corvette parts, lightweight and proven. Cost and the ability to find one being the only disadvantages. I remember being at the Moroso road course several years ago and having one of these fly by my C5 Z06. I had to check to make sure my car was actually in gear. Unfortunately it was.
Jason, how does the LS2 based 427 compare with the LS7 Street Attack? Advantages and disadvantages, cost, etc.
This will surely be a monster!
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
A wide-band air/fuel ratio sensor for each cylinder !! No excuses on the tune for this bad boy.
Maybe you and I will have to trade off a Beast drive for a MT900KR drive!
Schweet!!
Specifically, the MT900's using the side window design done in the UK...the last thing I did, before leaving Mosler, was brief them on my window design, that would allow the full side glass to go down. This was the first production car, with the full window: Click me, to see
unreal cars, there are one or two here in boca raton one is WM's partner in one of the companies, we see it around alot, leave your lambo at home, this is a real car. I have been flowing his products down her since the early dodge powered consuliers. They def got it right with this bad boy.
Good job K tech good job Warren.
NOW I am getting excited Mike - as the project starts to come together the reality is sinking in! I suspect the car will be able to scare the you-know-what out of me and I will definitely need to have a new level of respect for the power!
Everett,
Aside from seeing the car perform, I can't wait to hear how it sounds!
I have seen this car from EVERY angle () and there are few places for aerodynamic drag. It is so flat and clean on the bottom it must develop considerable ground effect down force.
With the light weight, new Katech power and more limber suspension, no one is going to be safe!
I am sure looking forward to seeing her again!
Congrats Everett!!!
Dean
Congrats Everett!!!
Dean
