New Delrin shift knob design
Old 04-17-2009, 11:50 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Default New Delrin shift **** design
Well, we have been making the Hardbar delrin shifter **** for about 10 years now, and never let it be said that I am not open to suggestions. One customer wanted it longer than the normal length we make. So, I made a few extra just in case for the threaded C4-C5 shifter and the smooth shaft C6 style. I decided what the heck, I have it, so why not try it. Guess what, I like it! It is like a variable rate shifter in that if you want it to have low force you push and pull it towards the top, and if you want minimum travel like an aftermarket short shifter, you have that as well, but using it lower. Same price as the normal one in our catalog, just let us know if you want the long one. I am keeping this one for me!
Old 04-17-2009, 03:40 PM
Everett Ogilvie
Everett Ogilvie's Avatar
I like it Gary. In a word - functional!
Old 04-17-2009, 04:40 PM
gkmccready
gkmccready's Avatar
How much taller is it?
Old 04-17-2009, 05:08 PM
ghoffman
ghoffman's Avatar
About an inch longer.
Old 04-17-2009, 05:11 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
I will take one for a C5. Can I paypal you the cash???
randy
Old 04-17-2009, 05:30 PM
ghoffman
ghoffman's Avatar
Here is the link:
http://hardbarusa.com/hardbar/produc...roducts_id=140
Randy, I will IM you a code.
Old 04-17-2009, 05:50 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Originally Posted by ghoffman
Here is the link:
Thanks dude!!! I just ordered one.
Randy
Old 04-19-2009, 06:36 PM
shifter77
shifter77's Avatar
Looks great
Old 04-19-2009, 07:44 PM
drivinfast
drivinfast's Avatar
Gary, Penskes are still great
I have the "breathless shifter" for the C6 with the stock **** on it now sitting higher than stock with their mod with the hole in the shaft to accomodate the stock C6 ****.
it is threaded for the C5 and sits a little higher than stock..would the C5 "normal" delrin **** drop the height?
Old 04-20-2009, 06:58 AM
ghoffman
ghoffman's Avatar
Yes, because you wrap you had around this rather than on top.
To New Delrin shift knob design
Quick Reply: New Delrin shift knob design
