Need Advice
Old 04-18-2009, 12:19 PM
SSWEET
SSWEET's Avatar
Default Need Advice
Normally we autocross our C4. Since we are driving our C5 auto to the NCCC Convention this year and will compete in the low speed events, I have a question? Our C5 has traction control and selective ride. Should we keep the active handling on and run in the performance setting?
Old 04-18-2009, 12:39 PM
TedDBere
TedDBere's Avatar
Since you're asking the question I'd suggest for this one event you leave the computer on and set the ride to sport.
If you want to autox it a lot, and be competitive, I'd set the ride to sport and turn everything off.
If you're running on your street tires I'd add pressure to the tires so as not to chunk them by rolling them over.
Quick Reply: Need Advice
