Pirelli P Zero Race Slick
How does a Pirelli Race Slick compare to a
1) Hoosier R or A?
2) Toyo R888
Looking to use for HPDE's. Thanks
Grip
Wear
Starting Pressure
Hot Pressure
Operating Temp
Set-up
1) Hoosier R or A?
2) Toyo R888
Grip
Wear
Starting Pressure
Hot Pressure
Operating Temp
Set-up
http://www.us.pirelli.com/web/motors...ssureform.page
I assume you are referring to Grand Am scrubs, otherwise disregard.
I start out at 22psi cold. 30 hot is ideal. I also run quite a bit of negative camber up front, 4+.
As far as a Hoosier or Toyo, there is no comparison, but then again the Pirelli is a pure slick so it's not apples to apples. You'll need a very good suspension to get the most out of them, otherwise you're wasting money.
Mike
