NT555R2, Lapping Day / AutoX tire pressure?
As the title says, what should my cold and hot tire pressures be for a lapping day and Autox on set of NT555R2 (275-17 front, 305-18 rear)?
The tires are mounted on stock rims on a C5Z06.
Thank you.
Thank you.
I had good luck with mine at 28/30 cold. Rears would get to about 33-34 hot depending on the track and ambient temps. At autocross, I started a pound or two lower since you can't really heat them up. If tire life is a concern, go with higher pressures as L98Terror said.
Tip - be sure to rotate side to side or you'll wear the L/F faster on most road courses.
