Need some thoughts and opinions...
Per the new T-1 rules I stripped the interior of the #86. As good as it looks I absolutely hate the driver side floorboard bare. I see in a matter of days that it will look like total, scratched up crap from grinding away with dirty shoes. I thought about leaving a piece of carpet in place with no padding but there is really no way to secure it down that I have found. Any thoughts on something lightwieght that I could use/install as sort of a permanent "floor mat" that won't end up looking like junk and may be easy to wipe up or vacuum?
I purchased three adhesive backed, non-slip stair tread toppers from Home Depot. (They are located in the paint section.) They have a very rough, surface on top and just "peel n' stick" to the floor. I find they provide a great non-slip surface, are cheap, and are easy to replace when they get worn out.
1 Post
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
I screwed my in, my floor was very slippery when it was wet I just wanted somthing to wipe my feet on
Thought about the grip tape, just need to find some now. It's not just about looks either, I hate that slippery floor feeling as Ken states, forgive me for failing to map that out......
You know me, it's more than about looks anyway though. But I guess you loose points for being proud of the way your car looks these days and wanting to keep it in good shape if it is in your control to.....
