Good News Bad News!
Good News Bad News!
I just picked up my Kaufman trailer with ramps extended from the normal 5' to 6'. The car drove straight up the ramp and the door opens without removing the fender. Just awesome that I can do that without wood ramps.
the bad news, I got a service abs warning on the dic and service traction control light. I did replace the rear rotors last week but drove the car and all was fine. So I thought I would just check to see if the abs was working. I went down a back street at 50 hit the brakes hard and the front tires locked up and to be sure I tried again and the rear end nearly came around. For sure no ABS is working. What could be the problem? I am taking to the dealership MOnday as I have a track weekend scheduled next weekend at Roebling.
any ideas?
any ideas?
Did you check to see what codes were being thrown? I got the dreaded 1214, but after about 2 days, mine went away and everything is fine now. Not sure what the deal was. My searching found everything from bad grounds, to frayed wires to bad bearings, to bad relays. Hopefully it will go away.
BTW, you have some specs on your new trailer? I haven't heard of Kaufmann. Are they local? TIA.
1 Post
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
My was bearings, replaced all 4 and the issue went away, I was fighting it for a couple months
It turns out that the ABS module was shorting out. I have it in the shop now and it is being replaced. You have gotta love the extended warranty. That puppy cost $1,400 to install. My dedectible is $75.00 so I think have covered the cost of my warranty and have 3 years left on it.
kaufman is in central NC, although I'm sure they have dealers everywhere. A friend of mine got one, and we picked it up right at their factory
Other than a wheel bearing or two (he never lubed them to my knowledge) he's really enjoyed it
