FS: Autocross Wheel & Tire Set-Up
Old 04-28-2009, 08:04 PM
Racer Buzz
Racer Buzz's Avatar
Default FS: Autocross Wheel & Tire Set-Up
For Sale: Corvette Autocross Wheel & Tire Set-Up
I have a mixed set of 2-Mallett & 2-Corvette wheels & 4-Hoosier AX Autocross tires w/Corvette tire pressure sensors.
FRONTS:
Two 1998 Corvette stock rear (18” x 9.5”) wheels with a 7.75” backspace & a 2.00” offset mounted with two Hoosier 275/35 ZR 18” used AX Autocross “A3S03” compound with Corvette tire pressure sensors
AND
REARS:
Two Mallett chrome rear (18” x 11”) wheels with a 8.25” backspace & a 3.00” offset mounted with two Hoosier 335/30 ZR 18” used AX / Autocross “A3S03” compound with Corvette tire pressure sensors
These are located in Ft Lauderdale, FL 33324
$850.00 OBO
Old 04-29-2009, 03:18 PM
0MrPickles
Former Vendor
MrPickles's Avatar
S03 tires are REALLY old tires... I mean well over 5 years since they were being produced. Hoosiers do not age very well, especially with long periods of time between heat cycles.
You would be lucky to get $40 a tire, without the rims. Since the S03 are 3-generations of A compound tires...old.
Good luck with the sale
Old 04-29-2009, 03:29 PM
AverageVetteNut
AverageVetteNut's Avatar
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
might be fun for local events
Very sharp wheels and good luck with the sale. Just bought a set of A6's
Old 04-29-2009, 03:59 PM
Leo z51
Leo z51's Avatar
Will the rears fit on a stock 07 C6 without hanging out of the fenders?
Old 04-29-2009, 06:48 PM
Racer Buzz
Racer Buzz's Avatar
A C6 has a bunch more wheel & tire clearance than a C5.
I did trim the inside fenderwell liners of my C5 with an xacto knife for another 1" of inside clearance to the frame rails..
To FS: Autocross Wheel & Tire Set-Up
Quick Reply: FS: Autocross Wheel & Tire Set-Up
