FS: 4 - Powder Coated Thin Spokes w/ Wide Oval Tires $400
$300 PICK UP ONLY TAKES IT NO MORE, NO LESS
-The pass side rear is bent - as you can see in the picture. I got a quote $80-$110 buks to repair it.
The rear tires will need to be replaced sooner than later. Belts arent showing but im thinking within the next couple thousand miles or less
These were professionally powdercoated gray.
Located in Pasadena Ca
I've got 3 sets of track/autocross wheels; so I'm not in the market in any case, so don't take offense at my comment.
1. You might get better exposure over in the wheels/tires forum
2. Thin spokes are going for about $150-225 a set (assuming C5 fitments). Powdercoating is at best a break-even value-wise. With one bent wheel you're probably looking towards the $150 range.
3. These look to be mainly worn out street tires, so their value is little to none.
OTOH, you'll never get it if you don't ask for it.
Good luck, and have a good one,
Mike
Mike
