Any one have this problem with Koni's Pics.
This bushing came out and now I can't get it back in all the way
I guess I need a press. Has this happen to your Koni, and if so
how do you stop it from happening again.
This is as far as I can get it in.
1 Post
Cruise-In II Veteran
Can you provide me with the inside diameter and length of the welded on tube? This is what I would replace it with using a flanged adapter to center the spherical bearing. Do you want to spend about $100 each though?
shocks. I will try and weld a plate first see if that works if
not will I guess $100 ea it is.
Richard
I bought a set of used 3013 's and the bushing is pushed out quite a ways. The seller suggested that I either press them back in (seems to be quite difficult) or swap them to the opposite side of the car from the way he had them. I need to figure out which way this is. The part that bolts to the control arm stays stationary, which way does the shock usually walk? Towards the front or back of the car?
Actually looking at it again it seems obvious which way they were installed because the mount has to be at the correct angle to meet the control arm. If I were to switch them I Think I would have to rotate the mount 180 degrees.
