Kam-Lok or Latch? Advantages and Disadvan..
Old 05-08-2009, 10:01 AM
EmilT
EmilT's Avatar
Default Kam-Lok or Latch? Advantages and Disadvan..
Seems to be some savings in going with a latch type harness. I am not trying to impress anyone. Am I missing some obvious advantages or disadvantages one way or the other?
Old 05-08-2009, 10:15 AM
Aardwolf
Aardwolf's Avatar
http://forums.corvetteforum.com/auto...-big-pita.html
Old 05-08-2009, 10:16 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
My latch-link works fine. Even with a HANS I still have no probelm getting it all put together.
Old 05-08-2009, 11:07 AM
0Vector Vette
Former Vendor
Vector Vette's Avatar
I have used both and prefer the convenience of the cam lock. You just slide each belt in once, and they stay there. I have had belts fall off the latch style while trying to get the next one on. Not a huge deal but also not much of a price differance in the grand scheme of things.
Old 05-08-2009, 12:43 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I still like a latch........I can get in on just as fast, and pulling the lever is easier with gloves than rotating. Plus, every time I get into a students car with the cam lock, they are ALL different, getting situated takes entirely too long!
Old 05-08-2009, 01:17 PM
WNDOPDLR
WNDOPDLR's Avatar
I have instructed with both types. I prefer the cam over the latch for the aforementioned reasons. I find the cam a lot easier to hook up and even though the cams are "ALL different", I find them faster than the latch. Hope I never get as old as David
Old 05-09-2009, 01:27 AM
0Vector Vette
Former Vendor
I use the Simpson cam lock. Flip the lever down and they all come apart. Flip the lever up and each belt clamps in and won't fall out. Nothing to twist.
I do think the world could use more cowbell in it though.
Old 05-09-2009, 07:28 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
In boat racing we used latch less chance of failure, they work fine. I have a cam in my car now. Some times I put the belts in the cam and they seem to be locked and then one pops off.
Old 05-09-2009, 08:21 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
That is why I don't like the Simpson, I snagged it with my driving suit . The Teamtech rotating release cannot be snagged like the lever.
Old 05-09-2009, 11:14 AM
thehammer69
thehammer69's Avatar
I have had bad luck myself with cam locks that use levers. When Autocrossing, and working hard through a series of elements, on occasion my hand would hit the lever and my harness would release. I switched to a rotating release style cam lock and have Never had an issue since.
Old 05-09-2009, 03:58 PM
trackboss
trackboss's Avatar
I'd have to agree with the above. The team tech is THE way to go on harnesses. I use them on all my installs. The huge crotch pad is what first sold me on team tech. After using the jet pilot I wouldn't use anything else. Awesome harness, but just as important it is super easy to install because it is a six point, but only requires four mounts. Worth the price.
Old 05-10-2009, 05:47 PM
John Shiels
nothing like protecting the jewels!
Old 05-10-2009, 08:51 PM
PA Z06
PA Z06's Avatar
I have a team tech cam locks on both sides, and I really like them, I have used latch a couple of times in different cars and cam is alot easier.
Old 05-10-2009, 08:52 PM
0Robert@SPEEDSOUTH
Former Vendor
Robert@SPEEDSOUTH's Avatar
I've used Simpson Latch, Simpson Camlock, and G-Force Camlocks. I like the G-Force cam locks the best, never had a problem, and I've been running with them now for several years. I always check the cam trigger everytime before I connect just to make sure its ready to receive the belts and then pull on the belts once everything is connected to ensure I have a positive engagement.
A weird note about the Simpson Camlock. I actually had the sharp edges on the trigger scrape the underside of my forearms a few times.
To Kam-Lok or Latch? Advantages and Disadvan..
Quick Reply: Kam-Lok or Latch? Advantages and Disadvan..
