"I can't drive F55"
"I can't drive F55"
Did my first track event at Summit Point last weekend with my 2006 with magnetic selective ride F55. I used with this setup for two years of high speed autocrossing on abandoned runways, so I know how to generate decent cornering and braking forces with the car.
With the elevation changes at Summit Point, I rubbed holes in all four plastic fender liners because the springs and shocks are so soft, even in "Sport." The track photographer got some shots of me in a braking zone where the black plastic front air dam is in contact with the roadway across it's entire width.
Going to fix it by installing a set of HardBar dual rate coil overs and Penske two way adjustable shocks. I've ridden with Gary Hoffman in his C6Z06 with this setup and it rides very nicely on both the street and the track, so I doubt that I'll miss the F55.
I'll post pics of the install after I receive the goods.
Wayne O tracked his F55 for a long time and really liked it on the track. He had Z06 sway bars, then latter went to wider wheels and bigger tires and T1 bars.
However....he's been progressively turning the car into a track only machine and finally switched over to either regular shocks or coil-overs. Contact him (or maybe he'll pop into this thread) if you have any questions about the conversion.
I believe he had to go to the dealer and get them to use a Tech 2 to "de-program" the F55.
Bob
Bob
Bob
Bob
Bert
I have used many sets of 5 W/15 OHM without a problermo.Ceramic resistors at about $4-$5 for a set of 4. Needless to say trim wires,tape and waterproof well. Consider just changeing to the PFADt shocks and bars.
F55 Delet
The F45 can be handled with the resistors, but the F55 has to be programed out. My dealership handled it with a Tech II and less than 90 minutes.
I have gone to Pfadt coilovers and couldn't be happier. I was told I would need a very sharp tuner with access to upgraded GM software and the going rate on the left coast was $650! It really had more to do with islolating the suspension module and telling the BCM not to look for it. One hour labor and I was on my way to RSD for my coilovers.
No codes and no performance issues.
I was using the Z51 stock setup, even now I am giving up on it with stiffer shocks. The R comps and the aggressive brake pads really show how soft the car is. I already spent $100 fixing wheel liners from car rubbing, I guess spending $1K on shocks will fix it
It isn't an issue with ride height nor am I planning to change the ride height -- the springs and shocks are waaay too soft for how hard I am driving the car. If you are at NHMS on the 21st you'll be able to see it or if you are at Devens on the 31st I can take you for a ride.
Bert
CF Senior Member
Bob
Bob
We have a new track facility opening soon in southern Arizona with a 2.75 mile road course including 100 ft of elevation changes...can't wait!
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
The bigger issue is for people like Bert & I who do both autox and track events.
Generally you run much stiffer springs/shocks for autoxing
I've been doing the 'using shocks as springs' deal for 10years with my soft base suspension.
I'm really looking forward to upgrading it to coilovers. the dual rate springs I'm putting on should help things out.
Pictures of double adjustable Penske 8300 with HyperCoil dual rate springs
The dual rate springs combined with the adjustment range available on the Penske's provides a good ride over the New England crappy roads -- not a Cadillac ride, more like a BMW sports car ride. The handling improvements are dramatic. The cost of this mod was comparable to the cost of long tube headers with high flow cats and exhaust -- in retrospect, I should have done this mod FIRST.
Thanks to Gary Hoffman at HardBar and Richard Strout at Leading Edge Motorsport for all the personal attention and advice provided for the parts selection and installation.
Front Sorry for the dirt
Rear
Front canisters
Rear canisters mounted in storage bins
Rear
Front canisters
