C6 ZR1 Swaybars?
Old 05-14-2009, 10:03 PM
gkmccready
gkmccready's Avatar
Default C6 ZR1 Swaybars?
By now somebody must have checked these out. Where do they fall in the C6 base, Z51, Z06, ZR1, T1 bar ranges?
Old 05-15-2009, 08:08 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
I would assume that they are bigger as well as the springs because of all the front end weight the ZR1 has. It will be an interesting addition to your spreadsheet.
Old 05-15-2009, 11:10 AM
gkmccready
gkmccready's Avatar
:-) Hoping somebody has seen one of these cars up close and personal now and had a chance to throw calipers around the swaybars to get at least the OD...
Old 05-15-2009, 02:47 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Originally Posted by 6SPEEDZ
i measured a ZR1 that we had in and the bars were different front to rear. 33.48 mm front 31.29 mm rear.
http://forums.corvetteforum.com/c6-c...waybars-2.html
Old 05-15-2009, 02:56 PM
gkmccready
gkmccready's Avatar
That thread is... odd. One guy says 33.48mm / 31.29mm. The other guys says 1.5in (38mm).
And I agree diameter isn't everything, but it's something. And I don't think anybody is going to cut these open to find wall thickness. :-)
Old 05-15-2009, 03:04 PM
thehammer69
thehammer69's Avatar
I bet they are solid bars
Old 05-15-2009, 09:44 PM
LS3FORME
LS3FORME's Avatar
Been wondering the same thing, I asked gene culley for the info. but he has not replyed as of yet. I would thin the zr1 are stiffer or larger but the car has adjustable suspension so who knows.
Old 05-16-2009, 08:48 AM
rocsvette
rocsvette's Avatar
Springs and sway bars on ZR1 softer than on Z06; stiffness made up by the shocks. For example when you hit a curb on the track with a Z06 you need to prepare for the jolt, with the ZR1 those wheels just soften up and absorb the jounce keeping the tires firmly planted. Driving a ZR1 on a bumpy street is far smoother than Z06 or even Z51 suspension.
To C6 ZR1 Swaybars?
Quick Reply: C6 ZR1 Swaybars?
