Did you know GM bearings
Did you know that GM expressly says the rear wheel bearing on C5 is not compatible with the front? GM cautions on using the OE rear bearing on the front eventhough it fits. They claim some possible damage but I think the speed sensor is still the same. The SKF heavy duty bearing is just a splined bearing for use on front and rear.
Yes, this is correct. I specifically asked the guy at SKF about this, and he reassured me that all was well in using their hub front or rear.
Former Vendor
I replace my front bearing on my C5 with the SKF. And wanted to verify the speed sensors are the same? As after the change I started to have issues with ABS and active handling under track conditions. I was going to test them this weekend to see if I have a bad sensor. Can they be mixed like this or do all four have to be changed?
Former Vendor
SKFs interchangeability shouldnt be an issue. From what I know, you can use the SKF on all 4....
Its the GM bearings that should be used for front or rear specific.
Wheel speeds, AFAIK, are the same for C5s....
Originally Posted by coffey
Who did you talk to at SKF? I am trying to get a drawing with all the dimensions of that hub.
Did you buy the aftermarket C5/C6 hub, or did you get ahold of the ZR-1 hub (GM part)? The ZR-1 hub has more spline teeth (which wouldn't matter on the front) and more importantly, uses an "active" wheel speed sensor. I don't know if the connector is the same, but if it is and you hooked that up instead, it could explain your issues.
If you are getting funny readings from your SFK bearing read on: An SCCA T1 racer had a problem where the CEL would flash after new SKF's were put in. The problem was a bad new speed sensor in one of the new bearings. The speed sensor by his report should read just over 1000 ohms. I'm in the process of converting my C5Z to the new SKF bearings on all four corners and have verified that the OE GM front and rear bearing sensors are just over 1000 ohms. So if you are having issues CEL's the first thing is to check the resistance of the speed sensors.
The maker of the SKF bearing says this one bearing is for front and rear. Sorry if I caused any problems. I was actually trying to figure out if the front and the rear OE bearing where really any different other than the spline and basically an FYI to the community.
I emailed the part number to another guy on their website but haven't heard back since. So it would be great it you could get me in touch with your guy.
thanks
Guy's name is Ken Fegley. Lemme either try to get that for you, or check to see if it's okay to contact him directly (should be).
I did take a read on the originals and they were 1.083K and when turned as fast as I could by hand 500mv. The SKF read 1.175k and 1.081K and if they are turned I only get about 200mv but the manual said this is all with in spec. I have now checked all connections and will have to test on the track.
