**New Carbon flat bottom ZR1 Splitter from LG Motorsports**
Old 07-27-2009, 11:28 AM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Default **New Carbon flat bottom ZR1 Splitter from LG Motorsports**
Hi guys,
Wanting to add some performance as well as a touch of carbon fiber to your Corvette? Well I just finished up shooting some pictures of our new ZR1 style, full carbon front splitter. This unit is completely clear coated carbon fiber and is a bolt on item for Z06, GrandSport, and of course ZR1 cars.
Unlike the factory units, you can find ours at a much lower price and it also features a full flat bottom up to the factory air damn to smooth out under body air flow. Add style, and performance to your Corvette today with LG Motorsports!
All of this at a introductory price of only $895!!
Shown here on Lou's 2009 Z06.
Taking orders now, and I will be happy to answer any questions that you may have as well!
Also do not forget our other new Carbon products such as the fuel rail covers, cold air intake, and stay tuned for more upcoming carbon body work!
Old 07-27-2009, 11:57 AM
burners
burners's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
Very nice!
Old 07-27-2009, 02:54 PM
ssdeuce
ssdeuce's Avatar
Originally Posted by burners
Very nice!
Old 07-27-2009, 03:30 PM
yakisoba
yakisoba's Avatar
Do you make anything like that for the C5?
Also, this is a bolt on for the ZR1, but how about a unit for the "plain" C6?
It's a mighty fine looking thing, for sure!
Old 07-27-2009, 04:19 PM
Former Vendor
Working on more pieces now, I do not have a timeline for those just yet.
This will work on any of the ZR1/Z06/GrandSport nose cars.
Old 07-27-2009, 04:35 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
might be interested in this.......
do you guys no think it would be of benefit to trip the airdam even with the bottom of the undertray? The airdam under the nose of the front-breathing Z06 has always driven me crazy!
Old 07-27-2009, 07:10 PM
LG Motorsports
Premium Supporting Vendor
LG Motorsports's Avatar
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
The only reason for the bottom air dam on a front breather is to get better gas mileage. I got that directly from the GM WInd tunnel guys that tested it.
It creates LIFT because there is NO bottom breather on a Z06. No where for the air that is packed up in front of the dam to go.
And with a lowered car, the stock bottom dam is a waste.
if you are tracking your car, with the bottom dam, and you remove it plus add the front splitter, you will see really good down force up front.
Actually what you will see is LESS LIFT.
Lou G
Old 07-27-2009, 07:18 PM
Z06Fix
Z06Fix's Avatar
So on a C6 Z will you see less front end lift by just removing the lower dam? That would be a nice little free mod for track days
Old 07-27-2009, 07:19 PM
LG Motorsports
Originally Posted by Z06Fix
So on a C6 Z will you see more front end downforce by just removing the lower dam? That would be a nice little free mod for track days
What you will see is "less lift"
But however you call it, you will gain front high speed grip with the dam removed.
LG
Old 07-27-2009, 07:24 PM
Z06Fix
Z06Fix's Avatar
LG
lol. you answered before I could edit my post. haha
Thanks for getting back with me.
Old 07-27-2009, 07:25 PM
davidfarmer
thanks for confirming.......
so even with removing the airdam, adding a ZR1-style splitter, you expect to have LIFT (OEM hood, etc). I'd think you should be getting close to creating downforce if the airdam was removed. I realize the hood still "packs" air in the engine bay, forcing out the bottom, but intuition (really pretty useless in aero work) would lead me to think the car might create a bit of downforce.
Do you recommend adding the OEM fascia support (from the ZR1) for your splitter, or is it reinforced otherwise (radiator support, etc)??
Old 07-27-2009, 08:03 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
How much airflow is there under the car in each case?
Old 07-27-2009, 08:22 PM
Former Vendor
By comparison, this is a stock 2009 ZR1 front splitter
Old 07-29-2009, 03:32 PM
Screamin Z
Screamin Z's Avatar
Call me crazy. But does your splitter cover up the brake ducts? Hard to see from the picture
Old 07-29-2009, 04:03 PM
Former Vendor
No, the scoops from the splitter grab the air for the air ducts. They are still open.
To **New Carbon flat bottom ZR1 Splitter from LG Motorsports**
Quick Reply: **New Carbon flat bottom ZR1 Splitter from LG Motorsports**
