Sparco Evo's in a C4 - Rail adaptor ?
Can you separate the factory seat rail in a C4 and reuse it with the Sparcos (similar to a C5 setup) or ?
Thanks!
Thanks!
Yes, you can take the factory rails off and use them for a bottom mount seat. Although, I'm 6'0 and with the power track I was WAY too high up to fit with my helmet with a Kirkey seat, even as low as the track could go.
But aren't Sparco EVO's side mount only? AFAIK the factory rail will only work with a bottom mount seat.
http://www.sparcousa.com/resourceFiles/26.pdf
I used custom mounts to mount Sparco Corsa's in my C4.
