Belt Routing With No AC
Old 07-29-2009, 01:22 PM
Kubs
Kubs's Avatar
Received 1,719 Likes on 929 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Default Belt Routing With No AC
I read several threads a while back about what belt size to use when removing the AC and AIR systems. I remember someone posted with stock pulleys to get a 27.75" belt and with underdrive it was something like 25.5". Well I measured mine with a string and got 25.5" with stock pulleys.. Maybe Im overlooking something simple but heres what I measured. Looking at the front of the engine the string went up the left side of the crank pulley to the left side of the waterpump pulley and over top to the top of the alternater pulley then down the top/left side of the power steering pump and back around the right/bottom of the crank pulley. Maybe the 27.75 was with an AIR delete pulley?? I just want to make sure I get the right belt and Im not missing something.
Old 07-29-2009, 01:23 PM
ryan0
ryan0's Avatar
I thought a/c was its own belt.
Old 07-29-2009, 01:25 PM
Kubs
Kubs's Avatar
oh sorry this is supposed to be in the C4 tech section.
To Belt Routing With No AC
Quick Reply: Belt Routing With No AC
