air injection removal
Old 08-05-2009, 04:20 PM
mgarfias
mgarfias's Avatar
Default air injection removal
on a C5Z. Is this possible without pissing off the ECU? If so, whats involved?
Old 08-05-2009, 04:22 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
you gotta turn off a few things in the ECU with a tuner
Old 08-05-2009, 04:24 PM
mgarfias
mgarfias's Avatar
Not a problem. What do I need to turn off?
Old 08-05-2009, 04:27 PM
drivinhard
drivinhard's Avatar
using HP tuners?
IIRC most of them are just unchecking the A.I.R associated boxes in the MIL table. (I don't have it in front of me, and my memory is hazy)
I can check later tonight
Old 08-05-2009, 04:31 PM
mgarfias
mgarfias's Avatar
Thanks. And EFILive, not HPTuners. But whatever, same basic stuff.
Old 08-05-2009, 09:13 PM
davidfarmer
davidfarmer's Avatar
just disable whatever new codes pop up when you remove it.
To air injection removal
Quick Reply: air injection removal
