C 4 Fuel Pickup Problem on Track
I know I have seen step by step instructions dealing with C 4 fuel pickup issues. The solution was to gently bend the in tank pick up tube. Can anyone send me a link to that thread?
Yes. This could be the source of your problem. Over the years, others have commented about it. When just below a half tank, and I turn left on high G turns, on either a sharp turn or a sweeping turn, I sputter. The problem is temporarily resolved by pulling into the paddock and fueling up. The proper fix is to bend the pick up tube into a different position.
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Go to:
http://forums.corvetteforum.com/auto...-gas-tank.html
This is the thread. 96CollectorSport had the answer back then, too.
The cheapest and easiest thing is to just fill your car up after each session.
Richard Newton
Richard Newton
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Go to:
Very true. But it looks like I may be working on my fuel pump, so while I'm there, I can easily correct this problem.
(BTW, My tow hook performed admirably last Monday).
Go to:
The sock should rest on the bottom, check if it does when you go to bend the assembly. Mine won't stutter till I'm into the bottom two bars, reserve light. I don't like to run over 1/2 tank because of all that extra weight. The stock tank is so long, I was thinking of putting fuel cell foam around the pick up spot.
I also have this problem and can't go below 1/2 tank. I tried bending my pickup tube but that hasn't seemed to help much. I saw something that Melrose T-Top had a bolt in 'cage' to hold a fuel cell in the stock location, but I haven't been able to find any information about it.
Could you share that info with us when you find it?
Here is all the info I have:
From this page:
http://tccracing.com//joomla//index....d=42&Itemid=99
and at the bottom of this list:
http://www.tccracing.com/melrose.htm
From this page:
Melrose T-Top offers a nice unit that will bolt in where the existing rear bumper was. This is a complete setup including the cell, the mounting bracket / bumper, fuel filter, and all the hoses and fittings for around $1500.
