Sway bar end links
Old 08-13-2009, 04:13 PM
LEAVINU
LEAVINU's Avatar
Default Sway bar end links
So besides the obvious of less flex with aftermarket links what other benefits will one see upgrading the links from stock? How does it improve the driving experience overall?
Would like to understand the total benefit behind them before I dig further into purchasing a set.
Thanks.
Old 08-14-2009, 03:05 PM
VetteRacer725
VetteRacer725's Avatar
Old 08-14-2009, 03:11 PM
froggy47
froggy47's Avatar
Thanks.
Good if you want some sway bar end link noise (click/clack) to listen to.
Old 08-14-2009, 03:15 PM
SLandstra_Z06
SLandstra_Z06's Avatar
Thanks.
In order to take pre-load off the sway bars when corner balancing the car, you need an adjustable end link. The LG Quiet-Links are an excellent product. No noise in the year I have had them on the car and I track it regularly.
Steve
To Sway bar end links
Quick Reply: Sway bar end links
