Individual Transmission Gears
G-Force transmissions makes different and stronger ratios. http://www.gforcetransmissions.com/tran_gt-56.asp
T56Ratios.pdf
T56Ratios.pdf
I haven't done anything with gearing yet either......too busy breaking valvetain components
Race gears are on a per case basis for whatever reason for individual gears, if you were looking for a whole gear set that should have been available (although costly) , but any T56 parts are available. Rockland is the largest T56 outlet in the nation. I just spoke with Mike Wienberg ( the big **** ) and he said the above is absolutley untrue.
Also, RSG does not even make the gears, they paid for someone else to do the tooling... its amazing what you learn at PRI.
Edit:
Danny, I'm talking about their close ratio gears, not stock ones. I'm 100% sure they'd sell you stock gears, or entire gear sets with no problems.
Just to let everyone know...
Spoke to G-Force...They dont sell individual gears, only gear sets...of which they only change the overdrive gears.
RS Gear has not gotten back to me yet.
RPM has and is willing to sell individual gears (standard ratios only, no custom).
To change ratios you can't just change individual gears, must replace individual gears and cluster gear to work........The custom 5th-6th gear seats can be used by themselves with 5th and 6th and the 5th-6th gear cluster......thats typically why they are not available individually. If you already have custom gears and need a single gear because of damage that is a different story.....
Custom gearing is waaay to pricey.
I cant get my engine to spin as high as I would like, so I am forced to use 5th gear. With that in mind, the changes above, coupled with a 3:90 rear and 7k rpm, puts me right where I want to be.
BTW - It would be nice if you could come to the South East once in a while and run Road Atlanta, Barber, CMP, etc. It would be a real pleasure to have you out there...if you ever do, please let me know...
