Corner Weights
Old 08-22-2009, 06:10 PM
gkmccready
gkmccready's Avatar
Default Corner Weights
My 2006 C6 Z51 with various modifications came in at 3239# with half a tank of gas. 867# LF, 831# RF, 757# LR, 784# RR. Add in 200# for me, shuffle things a little, and my final weights were 929# LF, 861# RF, 849# LR, 806# RR... 49.6% cross weight, 51.9% front, 51.6% left side.
Just curious how other folks typically have their weights end up. 861# per corner would be perfectly even for me at 3444#. At that weight if I could get 51% F, 49% R the fronts would end up 878# and the rears 844#.
For the record, I had stock bars and stock endlinks, with my weight and the bars connected: 936# LF, 849# RF, 835# LR, 820# RR. Disconnect the swaybars: 925# LF, 860# RF, 846# LR, 808# RR. I was pretty shocked by the weight change there. The bars were nice and free, shimmed as necessary, VBP poly bushings, but stock endlinks.
Old 08-23-2009, 12:26 AM
mgarfias
mgarfias's Avatar
My 01Z came in at 3400 with my fat ***, 1/2 tank fuel, and 75lb of ballast in the pax seat.
Unfortunately, I don't remember what the corner weights were, I should find another set of scales and do it again.
Old 08-23-2009, 06:13 AM
Nimo
Nimo's Avatar
St. Jude Donor '08-'09-'10
I had my 08Z weighed (no adjustments done) between sessions at Laguna - Full tank, me inside (188+cloths+wallet+helmet and stuff), R6s 315/18 - 345/18, Hotchkis sways connected, yellow top batteri.
Total 3375:
Front: 842/818 - 49.2%
Rear: 875/842 - 50.8%
Cross 50.1%
Never thought much about it as I haven't seen any comparisons.
/Nik
Old 08-25-2009, 04:06 PM
Rob Willis
Rob Willis's Avatar
Front Left: 926
Front Right: 857
Rear Left: 855
Rear Right: 785
Old 08-26-2009, 03:05 AM
96solo
96solo's Avatar
Total 3375:
Cross 50.1%
/Nik
Don't touch it! You can't get better than that!
Old 08-26-2009, 09:03 AM
argonaut
argonaut's Avatar
99 FRC with full tank, heavy street wheels and 175 lb driver:
LF 907
RF 872
LR 837
RR 811
Total 3427
Old 08-26-2009, 10:29 AM
2MCHPWR
2MCHPWR's Avatar
98 coupe with 3/4 gas, me in it (190 lbs.), coilovers adjusted, 295's front and 315's rear all on ccw's. steel DRM rollbar. corbeaus.
LF 888
RF 877
LR 847
RR 855
Total 3467
Front 50.89%
Cross 50.27%
Link to chassis setup sheet: http://209.177.55.37/images/c5images...06-04-2009.jpg
I just put z06 catback on and saved 18 lbs approx I think. Should lower overall weight to 3449.
Old 08-26-2009, 12:39 PM
C5X2C
C5X2C's Avatar
LF - 897
RF - 881
LR - 787
RR - 762
3328# with a full tank and 175 for the driver.
Front - 1778
Rear - 1549
Left - 1684
Right - 1643
Old 08-26-2009, 01:57 PM
Nimo
Nimo's Avatar
Too late
But a random sets of events lead up to this point, so it may still get back there.
Well, not really random; the guy that did the measuring said he rarely worked on vettes as they were very close from the factory. - He gave some horrible examples for other cars, but I don't recall which.
/Nik
Old 08-26-2009, 03:12 PM
63Corvette
63Corvette's Avatar
Total 3375:
Cross 50.1%
/Nik
What were your lap times at Laguna Seca?
Old 08-26-2009, 04:12 PM
Nimo
Nimo's Avatar
1.44 with some traffic, but the stock springs were getting too soft at that point. Fixing that now
Nik
Old 08-27-2009, 09:00 PM
haikun
haikun's Avatar
Just got my car weighed, 04 Z06 (with me at roughly 200 pound and full tank)
LF 915
RF 880
LR 857
RR 822
Cross 50.0%
Front 51.7%
Rear 48.3
Total 3474 ! Need to get some stuff out of the trunk
/Hakan
Old 09-17-2009, 09:24 PM
Nimo
Nimo's Avatar
Got my car checked today with street tires, full tank and 185lbs dead weight. Now with coilovers.
- Car was not adjusted as difference was within acceptable variance. (Porsche specifies 40lbs as the limit for adjustment, GM doesn't have one?)
Total 3401
Front: 844 819 -
Rear: 895 843 -
Sum Side: 1739 1662 51.1%
Cross : 1714 1687 50.4%
While it looks like the car gained weight since last time, my street wheels are heavier (19/20 combo vs 18/18).
Track wheels are 212.5 and street wheels 247.8, so 35.3lbs more.
/Nik
Old 09-17-2009, 10:13 PM
longdaddy
longdaddy's Avatar
damn and I though i was heavy - 3350 with half a tank of gas, driver, oem c5z wheels. that's with a beefed up rollbar but before i switched to coilovers
cross distribution was very similar to Nimo's, I can't find exact numbers.
Old 09-18-2009, 12:11 AM
Nimo
Nimo's Avatar
Not sure about heavy? - Mine would be 3305 with half a tank, me and track wheels.
3401 - 35.3 - 60 = 3305.
(full tank is 112.5, assuming 6.25 per gallon for 18gallons)
I think I may have added weight with my coilovers as the stock C6z springs were very light. Stoptech 15"/14" also added weight.
/Nik
Old 12-17-2009, 08:50 PM
gkmccready
gkmccready's Avatar
Updated 2009/12/16 (06 C6 Z51, Wilwood SL6R front brakes w/ NAPA rotors, DRM coilover, HardbarUSA harness bar, CCW C140 18x10+18x11 w/ R888s, DRM/RD Radiator, Pfadt Original Comp swaybars, half tank of gas):
LF: 889 RF: 875
LR: 851 RR: 817
Total: 3432#
Front: 1764# (51.4%)
Left: 1740# (50.7%)
Cross: 1726# (50.3%)
Old 12-17-2009, 09:43 PM
fatbillybob
fatbillybob's Avatar
For as well set-up and as light as my car is I should be faster. My T1 buddies would kill for these numbers. That's me in the car and with electric windows that still work and 1/4-1/3 tank of gas I forget now. Maybe my scales are broken?
Old 12-17-2009, 11:26 PM
jlvink66
jlvink66's Avatar
Here are my weights with my 2006 Z06 with coilovers, a 12 qt dry sump, 1/4 tank of gas, and my 200# fat ***.
LF - 856# RF - 827#
LR - 848# RR - 793#
Total - 3324#
Cross - 50.3% & 49.7%
Rear - 49.3% Front 50.7%
I have the Pfadt sways with adjustable heim links. Adjustable links are a must if you want a neutral setting for your suspension.
To Corner Weights
Quick Reply: Corner Weights
