c5z 10.5x18 all around?
Can I run this for a DE day? I happen to have more rears than fronts & not worried about classing etc.
Would have 315's all around. Lowered on stock bolts front all the way. could raise if needed.
I have had the 10.5x18 on the front with a 315/35 V710 on the front and it will rub at full lock (autocross). I did not have any fender clearance issue or rubbing on a fairly bumpy course, but loaded up at speed on a roadcourse you may have the tire do a little clearance work on your fender This is lowered on stock bolts just shy of maximum.
I would think a 295/30 would work pretty damn well on the front.
Fej
Fej
