c5 & c6 control arm differences
Is there a difference in the arms? Some say yes because part number change and others have told the change is so minor not to worry about.
Anyone know for sure?
the fronts should be the same, or very similar. The rear uppers are different to compensate for the longer wheelbase, but I think the rear lowers should be the same-ish, as the wheelbase change was made in the subframe.
1 Post
Cruise-In II Veteran
Well, I did a comparison of the rear upper C6 and C6Z and it appears that the only difference is the way it mounts and the associated bushings. The C6Z has the "dogbones" like the C5 and C6 front uppers.
