how much brake fluid is called for in the factory manual??
Old 08-26-2009, 11:19 PM
dvandentop
dvandentop's Avatar
Default how much brake fluid is called for in the factory manual??
my friend brought 2 qts of SRF to a place he had his brake changed out and also fluid bled, he said he wanted any extra back. so when he picked his car up they said there is none left over and the fluid does not even look that clear??
WTF i changed all mine out to SRF with just under 1L and had a little left over. I told him i would go bitch and get the left over back from whatever mechanic too the leftovers.
Quick Reply: how much brake fluid is called for in the factory manual??
