Traction Control/ABS Issue
Old 08-31-2009, 08:52 AM
crazyrondo
crazyrondo's Avatar
Default Traction Control/ABS Issue
Autocrossing the 02 Z06 Sunday, its hot, 102. First run hit the brakes, front locks up? does this the whole run. Second run same thing...dash lights up like a christmas tree, ABS light, "Service Traction Control Now"
I run with traction control off????
Park the car, I'am done. 4 hours later get into the car all cleared up, drive home is normal, did a mild canyon run home all felt fine.
What gives? Heat in the control module? this would be very bad on the track!!!!!
Thanks for any input
Old 08-31-2009, 08:57 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
First place I'd look is the ABS sensors on the bearing hubs.
Old 08-31-2009, 09:04 AM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Hubs
When mine did that I looked at everything it didn't go away until I replaced the hubs. On a side note I TTed half the season with that issue
Old 08-31-2009, 09:10 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
You're just trying to scare people into giving you point-by's.
Old 08-31-2009, 09:53 AM
L98Terror
L98Terror's Avatar
You have no idea, the next event after Nationals in 2007 I almost got turned away from a NCCC event at Gingerman because of hubs and tie rod ends, I had to put the e-brake on to limit the movement. By my last run it was making so much noise I decided myself not to run Grattan the next day. Not really the smartest idea ever, but I need to save my $$ for tires.
Old 08-31-2009, 11:09 AM
autox_vette
autox_vette's Avatar
Mine did that a few years ago. When I got home and unloaded the car, all of the DIC messages had cleared. Took it out for a spirited run on the back roads and they all came back when I launched it with the TC turned on.
Took it into the dealer and it was the ABS controller (~$900). They said it could either be that or the module (also ~$900) or both. Luckily, mine was just the controller.
Old 08-31-2009, 07:31 PM
Makofoto
Makofoto's Avatar
What's the name and contact info for that fellow on the Net that repairs Vette ABS Controllers/Modules?
Ron ... you're car wasn't much fun to drive yesterday.
Is this intermittent condition the beginning of the end of your controller or modules?
Old 08-31-2009, 07:41 PM
mgarfias
mgarfias's Avatar
This guy?
Old 08-31-2009, 08:00 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I'd say 95% of the time it's the wheel-speed-sensors in the bearings. Even if it never happens on the street, the bearing is always my top choice source for the problem.
Old 08-31-2009, 10:57 PM
crazyrondo
crazyrondo's Avatar
Mako, post below is the ABS guy.....got it from Steve T.
more ABS/TRC info
http://forums.corvetteforum.com/c5-tech/2188500-abs-module-question.html[/url]
Old 08-31-2009, 11:02 PM
crazyrondo
crazyrondo's Avatar
Default car sucked
Ya, parking the vette, back to Sti..
Old 08-31-2009, 11:24 PM
bobmoore2
bobmoore2's Avatar
Originally Posted by mgarfias
That's the guy. If you need a replacement module, then he will be able to save you several hundred dollars.
Displaying his url so it's easier to see: http://www.absfixer.com/
Old 09-01-2009, 02:43 AM
trackboss
trackboss's Avatar
I went through hell fixing my '99's ebtcm a couple years ago and ended up purchasing a new one which at the time was reasonably priced. Now a new unit is crazy expensive. I first tried abs fixer. He was a super nice guy and told me up front he generally cannot repair the older units, but he did try and didn't charge me since it did not work. My question is does anyone know why the older units, like my '99, cannot be repaired? At least not by a stand up company like abs fixer. There are some other companies that say they repair them, but I had to open up a dispute with my credit card company over the one I chose cause they were complete losers. It was almost a one year battle, but I did win. I would highly recommend absfixer, but stand clear of all other companies.
To Traction Control/ABS Issue
Quick Reply: Traction Control/ABS Issue
