Lesson not really understood, help needed
The suggested thought from my instructor was to try not to engage the traction control in turn 1 at Road Atlanta.
I was running in competitive mode and as I got faster, it would kick in when I hit that turn hot. Hot enough to warrant a slide close to the gators but I never felt like I was in danger of going off track. We would feel a little rear end shift and my instructor would tell me the traction control light would come on and he felt the rear right brake was being applied to help me out . He wanted me to try to make that not happen.
I wish I would have questioned him about it, but the day was cut way short and that last session after lunch was so much hotter running with the blue group that I was just taking it all in, then everybody went home due to the rain.
Anyway, upon reflection, I'm thinking the best solution would be to turn off the traction control. I sure didn't like it destabilizing my rear end right there. Yes I was sliding but I'm real confident I had enough track. What else could I do as a driver but slow down. Or maybe you say fix your line?
The couple times I passed going into turn 1 in the inside it would happen as my line was altered and full track usage needed. I hope Fred reads this, but I don't think he uses the forum much. We altered my line from previous days to utilize more track out there by turning in a little earlier. Previous track days I stayed wide later and ended up mid to 3/4 track out coming out of turn one. I think I was carrying more speed with the new line, obviously the traction control didn't like it.
How about some more instruction please?
If you were in Competition mode, it was the Active Handling that was acting. I probably sensed too much slip and activated one of the brakes. The Corvette warning systems are a bit of a nanny.
sometimes the system kicks in because it just doesn't like the situation, and sometimes it kicks in because you are overdriving. Without being in the car, it is impossible for me to tell what your case was, but I imagine your instructor felt you could track out a bit more to free the car up, or carry a bit less speed, to make the AH happy.
I have this happen occasionally with students, and often the only REAL remedy is to turn it off. However, that is a decision that you have to live with, as ultimately you may or may not be ready for it.
Don't let it get to you. I'd say there is a 50/50 chance that the light would come on no matter what you do (short of slowing down a lot), but it's always good to work on opening the corners up and applying smooth smooth throttle at all times. I personally feel you are NEVER truly driving the car until you turn the AH/TC off, but unless you are willing to accept the consequences, I never force a student to do so.
yeah... theres no way any of us could put up the times we do with the tc/ah on.
it is not meant for the track.. its overprotective to help the average street driver.
being too agressive with the throttle.
Un-winding the steering wheel and smooth throttle application should solve this issue.
Received 8,919 Likes
I don't think it is that over protective. There is a fairly wide dead band in comp mode where it doesn't do anything. Since the right rear brake was being applied the system was sensing excessive understeer as you were turning right. What set it off was how far you had the steering wheel turned to the right to keep the car on track. Several ways of handling the situation, ignore it as it really didn't mean anything or pay attention to it and determine if you could have done something better. What is the most likely thing that would have activated AH? Probably an early apex and too much speed being carried past the apex. You would be turning the steering wheel more to correct for this situation which would tell the system the car wasn't yawing to the right fast enough for the Gs it was pulling. Secondly, you may have added too much throttle as you started to exit the turn and caused the car to push. Since you are a student I suspect an early apex combined with being hot into the turn was the most likely cause. You felt you were in control but maybe the AH actually kept you from sliding out into those gators by getting the car to turn more than you could. Once you start driving very smoothly and hitting all of the marks AH rarely activates.
Bill
Bill
Ok, you bring me visions of turn 1 now. Its fast, sweeping, banked favorably, and uphill, so usually after apex I am back in throttle towards full. Ocasionally after apex, if I sense I'll be tracking out full to the gators I then go light on throttle. Maybe I do pinch a bit as I don't really like being full track out as it messes up turn two.
I have a totalled 2003 in my driveway from T1 (Mike's car). Traded to a C6 eh? At some point the AH will start to slow you down - especially if you drive the car "loose".
I think the key term here is the "sliding". Nanny help will almost always kick in during wheel slip.
I think you were a touch early on the apex, and a touch hot. The nanny may have helped, and it may have been a touch overly protective
I would try a slightly different line (later apex?), and if you data log see what works best. Other option is to back off a bit on the lap times and work without any "nanny" assistance and work your way back up when comfortable.
G'luck
Fej
G'luck
Fej
If you do this, be ready to BRAKE HARD at the top of the hill, making sure the car is STRAIGHT (aligned to track left at corner) !!!
Thanks for all the posts guys. You got me re-living the track so much that I would say it made up for one of the lost sessions the rain took away
That's typical as the student gets faster. Let the car run out... track left, it will come back to track center approaching the top of the hill.
T2 is a fluid turn under acceleration all the way to the brake zone prior to hopping the curb (or not as some run it) ....
You want the tires at ~ 5 to 6 degrees "slip angle", if you're sliding, you're losing traction.
Bill's right. Active handling in competitive mode doesn't really activate unless you are exceeding the tires limits/or over driving.
That said, the car is faster with the nannies turned off.
But only if you are able to push it to a razor's edge when cornering.
[QUOTE=varkwso;1571356285]yup do it that way so I can pass you on the inside....
Seth Thomas passes me in a Porsche 911 RS (the 250,000 Euro spec race car)...
But not in turn ONE.
Cya @ the track,
Trumper
Cya @ the track,
Trumper
