rear suspension squeak in 06 z
Old 09-07-2009, 11:10 PM
urslooow
urslooow's Avatar
Default rear suspension squeak in 06 z
Have Moton club sports otherwise stk suspension. low miles (24000) car tracked 2x/month. recently started hearing squeaking over bumps, esp a series or wave of bumps. handling feels normal, no shock leak, sway bar bushings look intact. what should I do? have a track day this sat the 12th. where else should I look?
Old 09-10-2009, 12:58 PM
urslooow
urslooow's Avatar
Brent from Primetime said to spray the bushings with some wd40, after checking if the suspension parts are tight. Remember function under load is normal. He said could be all the rain we'd been getting. Comments? suggestions?
Quick Reply: rear suspension squeak in 06 z
