Tire pressure DE/TT 710's
I'm used to being able to adjust between runs in autox, so this is a bit new doing 20 min of laps (1.6 mi course).
It's San Diego 9/24, probably cool am, maybe hot pm (air base on the bay).
c5z 295's & 315's.
What do you say?
For autox I usually run 29/25 or 30/26.
c5z 295's & 315's.
What do you say?
CI 4-5-6-7 Veteran
I aimed for 28psi hot, so I'd start the first session around 22-24psi cold and adjust accordingly afterward. Just take the first few laps carefully, which you should do anyway on cold tires regardless of pressure.
Thanks.
I was thinking of comp mode for about 1/2 the first session, then off the rest of the day.
I could never get mine that low with my factory camber settings. The lowest I ever attempted was 28 cold. The tires rolled over so bad that it actually wore off the treadwear, traction and temperature ratings off the side of my Hoosiers.
man I've been hanging around Toby too much....
