Frequency of transmission and diff fluid change
Old 09-12-2009, 04:49 PM
JSTAN
JSTAN's Avatar
Default Frequency of transmission and diff fluid change
I have an 02 Z06 that I use as a daily driver in which I put on between 7k-10k miles per year and I attend 3-4 HPDE each year.
What is the recommended frequency in which I should change the transmission and diff fluids?
Old 09-12-2009, 05:36 PM
rustyguns
rustyguns's Avatar
u should be good with an annual change! haul ***!
Old 09-12-2009, 07:38 PM
MungoZ06
MungoZ06's Avatar
St. Jude Donor '10-'11
And go with synthetics when you change ...
Old 09-12-2009, 10:01 PM
CHJ In Virginia
CHJ In Virginia's Avatar
Using full synthetic lubes a yearly change would be more than adequate for your driving criteria. My dual use Z06 runs about 8-10K miles total a year and 10-12 HPDE events. I have had no problems in the last 4 years doing a yearly change using Mobil 1 full synthetic lubes.
Old 09-13-2009, 08:02 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
When I was racing WC, with coolers, I changed them every 2 events. Obviously that was overkill, but I couldn't risk having a failure. Unless you are at the track more than 10 times a year, annual changes should be fine.
Old 09-13-2009, 08:09 AM
JSTAN
JSTAN's Avatar
Thanks for the all the responses.
To Frequency of transmission and diff fluid change
Quick Reply: Frequency of transmission and diff fluid change
