Pfadt Shock Mounts
Old 09-12-2009, 08:16 PM
stairman
stairman's Avatar
Default Pfadt Shock Mounts
anyone have any experience with the Pfadt delrin shock mounts.
car is torn down and need to get new mounts soon, the stock stuff is shot. this is a road race car only, do not care about noise and the such.
Old 09-12-2009, 10:08 PM
geerookie
geerookie's Avatar
Check out Gary's new shock mounts. Similar idea but a better application.
http://hardbarusa.com/hardbar/produc...roducts_id=141
Old 09-13-2009, 11:08 AM
stairman
stairman's Avatar
anyone tried the Pfadt ??
Old 09-15-2009, 02:35 PM
LS3FORME
LS3FORME's Avatar
I have them good product, a bit of pain to tighten the top down. The shock shaft moves, I think you can get a small wrench over the shaft near the adjuster. Some use a rubber strap wrench. The design is much improved over the old. I do recall one of the spacers, used in the upgrade kit was missing, and Pfadt sent it to me overnight.
Old 09-15-2009, 04:29 PM
froggy47
froggy47's Avatar
Here is my install thread, I have heard Gary's are also a good part, but I have not tried them. I would like to compare them but I always seem to need tires & rotors & pads.
Read down the thread.
http://forums.corvetteforum.com/auto...available.html
To Pfadt Shock Mounts
Quick Reply: Pfadt Shock Mounts
