Front feeding airbox for TigerShark nose
Anyone know of a pre-fab setup to change from a bottom breather to a front breather for a TigerShark nose? Also looking for proper TS brake ducts. Hoping I'm not going to have to fab these.
Thanks Nemesis, I'll drop a note to Lou about the front breather...Never saw anything about ductwork from Starcraft for the TS fascia. The openings are wider and a bit thinner than the stockers. Just want to plug & play without fabbing.
I have the Starcraft Tigershark on my street car and the brake duct inlet is about 200% larger than the stockers. Maybe the genuine Starcraft units will Plug & Play on the TS unit. Good Luck
1 Post
I don't know of a prefab front feed for the Tigershark, but since the air was passing though the tigershark gill (oppps I mean grill ) and being trapped in front of the radiator shroud (air filter location). I cut slots into the radiator shroud, this allowed the air to pass through the grill and into the radiator. I left the air dam for bottom feed in place, so I don't know if you would have overheatig issues if you removed it.
The radiator shroud is very soft rubber and can easily be cut with a utility knife. I didn't box it in to create an air channel but I don't think it would be too hard.
If you have the Starcraft Tiger Shark I would try to get the brake ducts from a vendor that sells them (to save alot of work). I don't know if they would work if you have the TSversion.
Thanks for the words and contacts fellas. Lg does make a sealed front breather for C6 ,but I'm waiting to hear back from them to see if they make a box specifically for the C5 or if I'll have to mess with the C6 unit...and I didn't know that StarCraft included the ductwork w/ the fascia.They don't mention it or show it in any of their ads. I did by one of their units from WCC,so it should be in there.Will call the body shop & find out.Thanx again, M3
LG's new sealed front breather is for C6 only....it may however be a bolt on for a C5 with Tigershark front fascia....dunno....let us know if you try or LG can give insight into this application.
Don't think the C5 radiator/shroud is the same as the C6. Got a flyer in the email to the guys at LG. I'll let you know what they say.
I'm sure the guys at MTI Racing could tell you all about the front breather on a tigershark...
http://www.mtiracing.com/image-galle...r-barber3.html
http://www.mtiracing.com/image-galle...lery/c5wc.html
