What camera?
What camera?
Need a recommendation on a camera for the track. Nothing fancy but something I can stick on the dash or windshield and easily remove to download.
I got this
http://www.goprocamera.com/index.php?area=2&productid=2
It's cheap and designed to do exactly what you want.
Ms Eliz
Ms Eliz
camera
I got this
Ms Eliz
Ms Eliz
It worked ok until i started loading memory, then it went crazy. Now it's a scrambled screen.
Ouch that sucks. I had to send mine back too actually, but because I dropped in on the concrete.
I use the single suction mount and additional articulating knuckle from chasecam.com
I just got a camera and used it for the first time this weekend and love it... a Canon FS10. Since all I will be using it for is the track, I went with a cheaper, re-manufactured one from ebay. In the end it was the same cost as the low end ones with the Canon quality.
EDIT: Forgot to mention that as far as cameras go, it is relatively small, although it is probably too big for a suction mount.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Main important consideration- EIS vs. OIS
EIS (electronic image stabilization ...i think) vs. Optical image stabilization.
I bought a panasonic 120 miniDV with EIS a few years back and it has worked great! no jitters, just good sharp image and sound. I especially like the extended mic cord with on/off switch so I can turn the camera on while leaving pit out....I bought the EIS type after reading about OIS can't take too much vibration.
However, I decided to try HD and they all seem to use OIS. What the heck, I thought I would give it a try so I bought a canon. Sure enough, video ain't wuff a toot....... So much vibration it is unwatchable.
Anyone else want to jump in on this issue?
I tried using my Panasonic with OIS, same problem. It can't handle the vibrations. Not to steal the thread but I'm thinking of going to the contour HD. Any feedback on it?
I use an Aiptek Action HD it was $150 at walmart.
Linkage
and this mount:
http://www.filmtools.com/gripper-302...era-mount.html
this is one of the best mounts i've used. It's ROCK steady (the sound is out of sync on youtube, but it's fine on the camera):
and higher quality:
http://www.vimeo.com/2145633
Linkage
and this mount:
and higher quality:
