Thunderhill track times...
In my most recent trackday at Thunderhill, I watched my in-car videos and tracked my times from the start/finish Flag, so keep in mind there is probably 1 second of potential variation.
My setup is a stock '09 Z06 running NT-05's (sticky streets but not R's).
When I wasn't in traffic I was consistently pulling 2:09 - 2:10 with 2 occasions where I ran 2:08.
After reviewing the video's I feel like I can shave at least 1/2 - 1 full second per corner (mainly braking later and throttle out sooner), which would drop my times to the low 2 minute mark and possibly 2:00 flat on non-R's.
How realistic is that??
What kind of times are you running at Thunderhill and what is your setup/mods??
Cheers
Cheers
Very. Your car setup well and good tires with good driving is sub 2min at t-hill. T-5 is faster with the bypass vs. going over the top. I've been told 2-5 seconds. Never done a back to back. My car is well under 2 min there with way less power than yours.
I forgot to add I ran with the cyclone, not the bypass.
Are you running R compounds??
What car are you running there??
My goal is to try to get down to low 2's or 2 flat on sticky street tires
My car is a '99 FRC. When I ran t-hill I was going over the top with a passenger so total weight was about 3600+lbs. Hoosier R compound. Bone stock motor and my own custom suspension setup. Car should now be a bit faster.
There are no real street tires that are sticky. The best dual purpose tire is probably a toyo RA1, but now I think you can only get the R888 which is similar. With as much hp as your car has your goal is realistic.
If I remember correctly Danny Pop did 1:52 in the Pfadt C5 at the 25 Hour Endurance Race last year. The third fastest lap for the entire field of 70+ cars (again my memory). There may be race data available to confirm.
Dean
Dean
Thanks for the feedback...
Sounds like my goal of low 2:00's or 2:00 flat on street tires (180+ wear rating, non-runflat) in a bone stock C6 Z06 (no tweaks) seems do-able.
The time from Danny Pop in the Pfadt C5 sounds good. I assume though it had a full bevy of Aaron's suspension parts, etc... and some sticky Hoosiers
I expect somewhere around a 2:04 without any drama, and probably a 2:02 with a little effort. With some real effort a 2:00 is doable.
Watch T2... my oil pressure can drop in to the teens...
Any chance you have some in-car videos or even better some telemetry data?? Would love to see your gear selection in the corners, brake points and corner entry/exit speeds
Search for "Fun with data..." as a thread and you'll find my data acq of a 2:07 lap. My money says 3rd gear everywhere except the straights where he gets 4th. :-)
The gears are obvious. The only place I remember them being in question is whether turn 1 is 5th or 4th gear. It would seem like that's crazy but IIRC you have to feather the throttle quite a bit in 4th whereas in 5th you just nail it, so you could go either way.
Also I just remembered, since they repaved the track (aug 2008) and again about a month ago, the track is 2-3s quicker. So fast lap in a stock C6Z should be around 1:56.
If you were just recently there, this kind of heat will kill performance on slicks, don't know about street tires but certainly the heat will affect engine performance.
