Free valve spring
Free valve spring
Due to a mistake I made installing valve springs on my car, I have 1 Patriot Extreem valve spring.
First to reply can have it. I'll even ship it out.
Steve
Steve
Ah, I think my friend is dragging his STi to RA this weekend. Please make sure to wave to him - been trying to convince him on a vette for a while now, but he just won't listen
What happened exactly, that left you not using a perfectly good valve spring?
I did a head/cam job last May. I bought a set of LS3 heads and a set of Patriot Extreem springs off the forum. For some unkown reason, I didn't get the base plates with the springs. The mechanic that installed the springs for me was not familiar with the Patriots, but did know that he could not mount the springs on the heads with out some sort of steel backing plate first, so he got a set of stock valve seals for it. That cured the spring to aluminum problem, but created another. The seals are a larger diameter than the inner valve spring. When everything got back together, it ran great, but we didn't know that the inner springs were binding. After a month or so of driving it and having it dyno tuned, it started a ticking that sounded like a valve that needed adjustment or a exhaust leak. I used a stethescope to listen to the engine, but at idle, it sounded fine. I found a exhaust leak and fixed that 2 days before we were to embark on a 2200 mile road trip.
About 500 miles into the road trip, the ticking that still was there became a pounding. At this time we stopped to check it out in a town called Cornwall, Ontario, Canada. I pulled a valve cover off and found that the retainer (titanium) on the valve closest to the firewall had broken, but that the center of the retainer had stayed in place and the inner valve spring had kept the valve from falling into the cylinder. Lucky for me. We happened to pull off the expressway next to a Chevy dealer, and a hotel right there, too. It was Sunday, so we took the car to the dealer on Monday morning. They took it apart, and found exactly what I had told them they would find. I told them to install a stock spring set up, and I would be on my way. The dealer screwed around trying to find a matching spring for a day. I had still not figured out what the real problem was. Meanwhile, I contacted Patriot, and they sent out a replacement spring and retainer to my home. Finished the vacation and got home with no more problems.
I talked to Patriot again about what had happened, and they informed me that the Patriot Extreem springs that were on the car were probably over stressed from the stock seals, and should be replaced. I purchased a new set of Patriot Gold springs (the Extreems were overkill for the engine, but I got a good price). Patriot sent out the springs and I started replacing them and noticed there were only 12 springs, but all the backing plates and retainers I needed. Called Patriot. They said sorry and we will send out the remainder. I guess to make up for it, they sent out 8 more springs, a couple of backing plates, and the additional retainer I asked for.
Its now all back together. It runs great. Sunday is going to be myone and only track day this year, but all facts considered with the springs, has probably saved me from buying a new engine.
And thats why I had 1 Patriot Extreem spring.
Steve
