DBA Rotors- do the hats hold up cosmetically?
Old 09-30-2009, 11:26 PM
Swiftwater Z06
Swiftwater Z06's Avatar
Default DBA Rotors- do the hats hold up cosmetically?
Those running DBA two-piece rotors on a C6 Z06 - do the hats hold up cosmetically?
Old 10-01-2009, 11:53 AM
Rob Willis
Rob Willis's Avatar
They don't stay black, they turn into a wierdish maroon color under heat.
But, other then that, they look fine.
Old 10-01-2009, 01:46 PM
longdaddy
longdaddy's Avatar
interestingly enough, black wilwood caliper finish does exact same thing, so my front brake colors match almost exactly
Old 10-01-2009, 02:18 PM
Zenak
Terminal Vette Addict
Support Corvetteforum!
Zenak's Avatar
if you are worried about the color... i suggest a high temp powder coating, or just JetHot for their pipe coatings some of which will be good up to 1400F
Old 10-01-2009, 02:29 PM
95jersey
95jersey's Avatar
I use to paint my NAPA rotors with black brake caliper paint as the NAPA rotors had no protective covering on the hat and would rust solid after the first wash.
If I didn't track the car, the paint held up 100%. If I tracked the car, the paint would slowly wear away at the part closest to the actual rotor, but always looked better than when left unpainted and just rusting.
To DBA Rotors- do the hats hold up cosmetically?
Quick Reply: DBA Rotors- do the hats hold up cosmetically?
