spring and sway bar swap.
You might want to take a look at the new Hyperco springs. I'm running Z51 bars and the Corvette Challenge springs. Keep in mind that when you swap the springs you're going to have to have your shocks revalved.
Bilstein added 30% more rebound into my shocks. And, I had a tremendous amount of rebound already.
Richard Newton
Intervention Motorsports
Twitter
Richard Newton
what about 84 z51 springs, i have bilstein hd's on the car now. my goal is for a solid street car that see's a hand full of track events a year. and i would like to run down a bmw m3 and a few other cars, i hope that this is a realistic goal.
Premium Supporting Vendor
The 84-87 front hyperco springs will work if you buy the 88-96 front craddle clamps and bolts shown here.
http://www.vansteel.com/index.cfm?fu...&SubGroup=1950
The 84 Z51 springs are plenty stiff for what most folks need. Remember that you really can't go much stiffer than that in the back before the car starts to jack, so if you balance that with the right front spring you are very close to being done. Just add a set of shocks and you are there...
