Budget/C6Z oriented suspension question for C5...
Old 10-07-2009, 04:32 AM
RideZX6R
RideZX6R's Avatar
Default Budget/C6Z oriented suspension question for C5...
So I'm planning on upgrading to C6Z shocks and springs and T1 sway bars on my C5 coupe...
The way I understand it... C6 shocks and front spring will work on a c5 and c6 sway bars will work on C5. C6 rear spring has different mounting hardware. So I can't use the rear Z06 springs on my C5.
What are you guys using for the rear springs to work with this setup then?
Thanks for the help!
Old 10-08-2009, 05:22 AM
RideZX6R
RideZX6R's Avatar
Not a single person?
Old 10-08-2009, 12:18 PM
mgarfias
mgarfias's Avatar
You don't have coil overs, the spring is separate from the damper on the rear. The c6z shocks should bolt on, but I don't know what you'll do for a rear spring to match the front spring.
Old 10-08-2009, 02:37 PM
RideZX6R
RideZX6R's Avatar
whoops just realized I worded it wrong, thats what I get for posting at 4am.
I edited it to have it worded right.
Old 10-09-2009, 04:02 AM
RideZX6R
RideZX6R's Avatar
and still no one?
springs for the rear?
Old 10-09-2009, 09:16 AM
ZO6NTHEWIND
ZO6NTHEWIND's Avatar
I am not very knowledgeable as most on this forum, but read a lot.
Why are you wanting to put C-6 parts on your C-5? If you want to 'upgrade' and are on a budget factory C-5 Z06 parts are a better choice.
Just MHO.
Old 10-09-2009, 10:25 AM
Independent1
Independent1's Avatar
St. Jude Donor '08
I don't know the answer to your question. Might want to try asking people who have done it what they did.
I know VBP makes springs so they might be a source for the rear spring.
Old 10-09-2009, 11:55 AM
mgarfias
mgarfias's Avatar
I think Hyperco makes a spring too. Might want to figure out what the rear spring rate is on the C6Z and see if VB&P or Hyperco makes a corresponding spring.
Old 10-09-2009, 06:36 PM
RideZX6R
RideZX6R's Avatar
Thanks guys I figured there was a vendor who sold what I was looking for ... just needed to know who!
Thanks!!
To Budget/C6Z oriented suspension question for C5...
Quick Reply: Budget/C6Z oriented suspension question for C5...
