Need Rubber Outer Tie Rod End Dust Seals/Boots
Old 10-12-2009, 03:19 PM
rikhek
rikhek's Avatar
Default Need Rubber Outer Tie Rod End Dust Seals/Boots
I need new outer tie rod end dust covers/boots for a 2008 Z06. GM only sells them along with tie rod ends. The seals/covers I need are the black rubber "cup" for the outer tie rod end.
Mine are melted from heat at the track. I didn't wrap them prior to going to the track. I thought they'd last a day with street pads and tires but they didn't....
Anybody know an aftermarket or OEM source and part number? Would they be the same for a standard C6?
Rick
Old 10-12-2009, 05:02 PM
wmckeenster
wmckeenster's Avatar
I got my replacements at Checkers and I think NAPA has them too?....the ones I got are the high temp red boots...
Hope this helps!
Old 10-12-2009, 05:35 PM
froggy47
froggy47's Avatar
Hope this helps!
Me need also. Any online source? I melted tie rod boots, caliper slide boots, caliper piston boots, sheesh.
Old 10-12-2009, 06:39 PM
gkmccready
gkmccready's Avatar
http://www.summitracing.com/parts/ENS-9-13101G/
http://www.vbandp.com/detail.aspx?ID=401
Old 10-12-2009, 08:06 PM
froggy47
froggy47's Avatar
Does Poly have a higher temp rating? Has anyone tried these (with success) on a track car?
Old 10-12-2009, 08:17 PM
ssdeuce
ssdeuce's Avatar
Thanks guys! I have the same problem.
Old 10-12-2009, 11:12 PM
rikhek
rikhek's Avatar
You're probably aware but just in case, the slide boots and piston boots are a lost cause. They'll melt as quickly as you can put them on. The tie rod boots and control arm ball joint boots can be saved by wrapping with header wrap or using a heat shield/reflector.
Rick
To Need Rubber Outer Tie Rod End Dust Seals/Boots
Quick Reply: Need Rubber Outer Tie Rod End Dust Seals/Boots
