Advice for 1st time at Roebling Road
Old 10-13-2009, 09:42 PM
Zippy
Support Corvetteforum!
Zippy's Avatar
Cruise-In 2, 9 & 10 Veteran
St Jude donor '09
Default Advice for 1st time at Roebling Road
Hoping to run my 010 ZR1 at the NCCC high speed event Nov 27-29 at Roebling Raod.
I've never been to that track and need advice/tips/suggetions, etc.
I'll be driving to the track and therefore running factory Michelin tires. Not trying to set any records nor damage the car. Just want to drive it at a speed I'm confortable with and have fun. Already have my NCCC hi-speed license and approved helmet.
Also loking for a source to purchase a fire extinguiser mount per NCCC rules.
Any help/suggestions appreciated. Thanks!
Old 10-13-2009, 09:50 PM
mousecatcher
mousecatcher's Avatar
i just read an article in our local SCCA region's magazine about a guy who went there. he said the track is perfectly flat (no tricky camber, etc), only 7 turns and extremely easy to learn.
Old 10-13-2009, 09:55 PM
drivinhard
drivinhard's Avatar
ping varkwso, I think he lives on the premises
Old 10-13-2009, 10:29 PM
*C7*
*C7*'s Avatar
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I have seen that house in the pit area but never knew who lived there!
He has helped me a couple of times.
Old 10-13-2009, 11:21 PM
Z06_BluByU
Z06_BluByU's Avatar
nice track.. its quick and has lots of run off room... just be wary of the pit wall opn the inside of turn 9..... if you run wide they suggested to us that we let the cars run out in to the field.. they said correcting could spell disaster and a kiss with the conc. wall...
you'll love the track.. loads of fun!!!
Old 10-14-2009, 08:40 AM
JDIllon
JDIllon's Avatar
The track is lots of fun!!! But watch turn 9, that inside wall eats cars 24/7. Find a shady spot in the infield and have a great day. JD
Old 10-14-2009, 08:48 AM
wtknght1
wtknght1's Avatar
This is a great site!!!! ...and has "Hot Lap" writeups for many tracks.
http://www.na-motorsports.com/Tracks...blingRoad.html
The bottom line on Roebling though is go fast and turn right. It's a good test track, but not a good place to race...as there's no place to pass. If you beat somebody into Turn 1, you could block like hell for the rest of the lap!
It's great for setting up your car though - one long sweeper after another. I have tons of video.
Old 10-14-2009, 09:00 AM
JimbeauZ06
JimbeauZ06's Avatar
Not exactly. Opinions on numbering vary by organization, but Roebling is generally considered a 9-turn track, Turns 1-5 are flat. T1&2 look like a single turn but are considered two separate turns by most. T6/7 begins a down-hill off-camber right hander feeding into a high-speed slightly off-camber turns 8&9 (or one extremely big turn which leads to the discrepancy in the number of turns). As mentioned there's really only one place to get in trouble is T9 (Last turn coming onto the straightway). Cars that track out too far, drop a wheel and overcorrect will slam the wall on the inside. If you find yourself in this situation just stay in the grass and gather it up. I think for your event they may add the "bus-stop" chicane about 3/4 way down the straight.
I have about 25 track days at Roebling. It's an awesome little track, recently repaved, lots of run-off room and even considering T9 very few spots to get in trouble.
Have a great time!
Old 10-14-2009, 09:05 AM
Zenak
Terminal Vette Addict
Zenak's Avatar
You Tube Man. You Tube.
You can watch any event, any course, any car is you spend enough time searching :-)
Watch, slow mo, look at turn in points. If they get passed alot its not the guy to watch. If they pass everyone else its probably a good line :-)
KISS
Keep it simple stupid!
Old 10-14-2009, 09:09 AM
bosco022
bosco022's Avatar
Watch this Video of Bob Mayer and his ex W/C Vette at Roebling
In car video of Saturday SCCA SARRC Invitational Challenge/ V8 StockCar points race from cockpit of Bob Mayer's ex World Challenge C6 Corvette.
Cars if front of him at the start are Bill Smith in the winged super late with SB2 chevy power and former Grand Am Champ Dave Machavern in a Tommy Riggins built Corvette. (these two jet off and Mayer battles with former three time Nascar Goody's Dash champ Larry Hoopaugh in the white Cup type Monte Carlo, Tony Amico in the black ex ASA Delco car. At one point Lee Arnold flashes by in his ex Ken Schrader/Boris Said Southwest tour car.
Mayer's car hangs pretty well with fastest stock cars despite having only about 420 rear wheel hp. Check out the straight line speed of Hoopaugh's ride.
http://www.youtube.com/watch?v=d6JtK0SkVf4
Old 10-14-2009, 09:18 AM
beerkat
beerkat's Avatar
RRR is a fun track and is sort of fast. You can drive the whole track in 4th gear if you want to, many people do. Depending on how brave you are you come out of the last turn at 100mph and can hit a 150 mph on the front straight before braking for the first turn.
Old 10-14-2009, 09:20 AM
Zippy
Zippy's Avatar
St Jude donor '09
WOW..great info, thanks gang!
Old 10-14-2009, 09:37 AM
drivinhard
drivinhard's Avatar
Originally Posted by beerkat
...and can hit a 150 mph on the front straight before braking for the first turn...
or a bunch more in a 640 hp ZR-1
Old 10-14-2009, 01:08 PM
Zippy
Zippy's Avatar
St Jude donor '09
I only have 638 hp.
Old 10-14-2009, 02:01 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Since I'll be one of the guys running tech just make sure the extinguisher meets the rules, 5bc with a gage mounted with a metal mount within reach of the driver. I'm sure there are lots of vendors with mounts that will attach to the passenger or driver seat rails.
Are you comming out for Friday as well as Sat/Sun? If you've never been to Roebling its a great opportunity to get practice laps in.
Youtube and trackapedia (sp) are great places for figuring out the plan of attack for the track.
Remember its a sprint start to the timing lights (event 1) then a full lap back to those timing lights (event 2) then exit a turn 4 (I think thats the turn with the service road). Just have fun, the turn1 & 2 combination is a little tricky. Cars will be spaced out so that even though there are 3 cars on the track you will probably not see the other cars. No "chicane" on the main straight, exit turn 9 with as much speed as you can and floor it all the way to the timing light then stand on the brakes. Street tires will be OK for you, especially if it rains.
See you there!!!
Old 10-14-2009, 09:57 PM
mlaur1
mlaur1's Avatar
Not sure where you live, but if you can break free this Friday, Seattime puts on a great event. You drive 30 min, sit out 60 (at most) and drive again for 30. After 1pm, they usually combine groups and it's 30 min on 30 min off. By 3, you are begging to stop! Most track time out of any event!
Feel free to email me for more info. Mlaur1@aol.com
Old 10-14-2009, 11:04 PM
Zippy
Zippy's Avatar
St Jude donor '09
mlaur1:
Live near Nashville TN. Where is your event?
To Advice for 1st time at Roebling Road
Old 10-14-2009, 11:05 PM
Zippy
Zippy's Avatar
St Jude donor '09
jaa1992:
If I go, yes, I'll be there for Fri.
Old 10-15-2009, 10:17 AM
jaa1992
jaa1992's Avatar
St. Jude Donor '12
jaa1992:
Whats holding you back?
The group even puts on a thanksgiving dinner thursday night!
We'd love to have a new zr1 out there!
Old 10-15-2009, 04:27 PM
Zippy
Zippy's Avatar
St Jude donor '09
jaa1992:
What's holding me back? On going medical procedure twice a week. We're trying to schedule it to have that weekend free.
Quick Reply: Advice for 1st time at Roebling Road
