Teaser...
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Lookin good! Its nice to see people go through the time to mount it right , instead of the decklid .
I'm calling foul!
if you need it, an 1/8" wicker at the back can help, especially at more than 9deg angle. You can't go much more than that (sans wicker) without getting serious stall (more drag than downforce).
Did you put a splitter on......if not, you won't need much wing.
I'm going to try the wing without the wicker first and go from there.
Cruise-In VI Veteran
This is the same car you originally towed to HPDE's on a U-Haul trailer, right?
Just look at you now!
Keep us posted on how it works. As I understand it, you will eliminate the squirreliness from the rearend under heavy braking as well as be more planted up the esses.
Bob
Bob
Yeah, but its toooooo cold up there.
