Need help with glue - pic
Old 10-24-2009, 07:48 PM
froggy47
froggy47's Avatar
Default Need help with glue - pic
I am trying to glue this parking stop to a door mat (so it doesnt skid on the garage floor).
I have tried:
Construction caulk (Liquid Nails)
2 part epoxy putty (Billy Mays)
Gorilla Glue
Loctite Plastic Epoxy (2 part in syringe)
PVC Blue Glue
GOOP - Plumbers version is working so far !!!!!!
Plumber's GOOP failed 7/17/10
That's not bad I guess, redid w/ same.
Any ideas?
I don't know the technical name for the hard yellow plastic, but it sure does not want to be glued. Everything sticks to the rubber door mat.
Old 10-24-2009, 07:55 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
http://solutions.3m.com/wps/portal/3...beQH8HT14PGTgl home depot has it or marine supply
Old 10-24-2009, 07:59 PM
froggy47
froggy47's Avatar
Originally Posted by John Shiels
I saw that stuff & was thinking of trying it, will do, thanks John.
Old 10-24-2009, 09:00 PM
GettReal
GettReal's Avatar
go to home depot, forget the little tube stuff.. get construction adhesive, think its called bulldog super strength. It fits in a caulking gun. Put it on the bottom of the plastic..apply to mat... put weight on it. Ive had great success using this stuff for tons of adhesive applications.
Old 10-24-2009, 10:12 PM
sperkins
sperkins's Avatar
The yellow plastic is probably high-density polyethylene (HDPE) or maybe polyvinyl chloride (PVC). Neither one will glue permantly to rubber. Your best bet is to pick up a plastic mat, glue the stop to it and then apply a 3M adhesive to the back of the mat to stick to the floor. Don't forget to prime the PVC so the glue will stick or better yet use screws to fasten the stop to the mat from the bottom.
Old 11-10-2009, 09:32 PM
froggy47
froggy47's Avatar
Plumber's GOOP was about 1/2 the cost of the Marine adhesive, so I gave it a shot.
If it fails, I'll try the Marine stuff next.
THX all
Old 11-11-2009, 05:34 AM
worldsaway
worldsaway's Avatar
You might try some 3M 5200 adhesive. I used to do alot of boat work and that's the best stuff ever made. I think it's considered a polyurethane adhesive.
Old 11-11-2009, 08:29 AM
ZR1 MK
ZR1 MK's Avatar
What about two screws. Or if you need to remove the stops to work on the car etc, use long pins instead.
Old 11-11-2009, 09:50 AM
beerkat
Support Corvetteforum!
beerkat's Avatar
You might want to try Carpet tape. I have used it to secure a wooden ramp to a tile floor and it has held for better than two years now. It also allows you to take it up without to much effort. Make sure it is Double Sided.
Old 11-11-2009, 10:05 AM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Use some clear silicone adhesive
To Need help with glue - pic
Quick Reply: Need help with glue - pic
