got some michelin slicks any tips from other users????
Old 05-10-2010, 09:58 PM
dvandentop
dvandentop's Avatar
Default got some michelin slicks any tips from other users????
Thanks to Daniel at Finspeed for getting these michelins in for me, cant wait to get them mounted on the ccw's and give them a testing. If they hook as good as everyone says they do i am sure i will be impressed!!!
sounds like they like lots of camber for them! reccomended -3.0- 4.0 up front
-2 to -3 in the rear
Old 05-10-2010, 10:19 PM
Everett Ogilvie
Everett Ogilvie's Avatar
Nice! You beat me to it. What sizes front and rear? What compounds?
Old 05-10-2010, 10:22 PM
dvandentop
dvandentop's Avatar
30 65 in front
and 31 71 in the rears
running the s8d(medium) compund in the front and the s9d (medium) in the rears
i also have 2 front 30 65/18 i got used off here that are the s8c (soft) compound i will try out eventually too
what size rims you running Everett??
Old 05-10-2010, 10:31 PM
Everett Ogilvie
Originally Posted by dvandentop
30 65 in front
Those are the same sizes I am considering. Hope I have enough room on the front. My new rims arrive in 2 days; 18X11 front, 18X13 rear. The 30 65 is technically supposed to be on a minimum 11.5" rim, but what's a 1/2 inch among friends....?
Old 05-10-2010, 10:42 PM
Short-Throw
Support Corvetteforum!
Short-Throw's Avatar
Derek,
I suggest you wait until Track Attack so I can break them in for you properly!
Start with cold pressure of 22 and give them a few laps to heat up.
Old 05-10-2010, 10:48 PM
dvandentop
dvandentop's Avatar
that's what she said
Mike yeah i will probably be running them the 1st time at track attack so will have the guys around who know how to get those babies dialed in
Old 05-11-2010, 12:17 AM
Kubs
Kubs's Avatar
Received 1,754 Likes on 941 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Those look sweet! I would love to try slicks one of these days.
Old 05-11-2010, 10:37 AM
Everett Ogilvie
What rim sizes are you using front and rear?
Old 05-11-2010, 10:49 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
My best advice is to send them up here so I can test them out. You don't want to take too many chances trying out a new tire. You should be lucky there is someone like me willing to try them for you at no cost.
Randy
Old 05-11-2010, 11:37 AM
dvandentop
dvandentop's Avatar
lol thanks guys
everett i will be using 18x11 and 18x13 ccw corsairs
Old 05-11-2010, 12:43 PM
Everett Ogilvie
When will you be able to test these for the 1st time - TA, or before? Let me know your impressions please! I am about to pull the trigger on some as well. Or, I guess I could "settle" for some Pirelli slicks like Mike does with the Beast......
Old 05-11-2010, 12:52 PM
dvandentop
dvandentop's Avatar
Everett i will shoot you an email when i get home to your personal email
yeah track atttack will most likely be the 1st chance to use them :-(
Old 05-11-2010, 12:53 PM
dvandentop
dvandentop's Avatar
mike how tall of rears do you run on the beast?
Old 05-11-2010, 01:16 PM
stairman
stairman's Avatar
lol thanks guys
better give your tire guy plenty of time, they are a Bitc* to mount on corsairs, in fact they will not even go on one set of mine. Then when it comes to beading them stand back.
the tires are like grease when cold but give them a few laps and they stick like glue.
Old 05-11-2010, 01:25 PM
dvandentop
dvandentop's Avatar
wow wonder how come they wouldnt fit on the one set of your ccw but would the others?
i know my tire guy has a bead blaster so i told him he is going to put that to good use :-)
he had fun getting my old goodyear slicks off when i used those up. he said the fronts were more difficult then the tall 28 inch rears.
Old 05-11-2010, 01:31 PM
Short-Throw
330-690
Old 05-11-2010, 01:51 PM
stairman
stairman's Avatar
its due to the size of the center of the wheel, tire will barely slide down, the one set is just a few thousands larger and the tire will not clear. You dont need a bead blaster, it is how much pressure it takes to get the bead to set. Goodyear slicks were a breeze compared to these.
To got some michelin slicks any tips from other users????
Old 05-11-2010, 01:53 PM
dvandentop
dvandentop's Avatar
how many psi did you see to get them to seat? i have heard close to 100 or so.
bet that is a loud pop when they do seat!
Old 05-11-2010, 01:55 PM
drivinhard
drivinhard's Avatar
put a penny on the section of sidewall about to seat and see how high it goes
Old 05-11-2010, 02:07 PM
stairman
stairman's Avatar
you will shoot your eye out kid.
it did take about 100psi, not a good feeling when you are standing there with it.
I liked them but they are just to loose to race on ( only good if everyone is running them ), by the time they warm up to many cars have gone by, I will stick with the A6's.
Quick Reply: got some michelin slicks any tips from other users????
