Z06 throws Low Voltage code
Old 05-17-2010, 12:51 PM
ERND IT
ERND IT's Avatar
CI-3 Car Show Winner
CI-4 Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '06-'09
Default Z06 throws Low Voltage code
had the Optima battery tested to make sure it didn't have a bad cell, so it appears that the next obvious problem is a bad alternator.
My question - which alternator is the correct one for my 2002 Z06?
Checked RockAuto - they list several choices for a manual trans - a REMY part #13381 with 110 amp and an ACDELCO #3341492 with 150 amp. how do I know which is the right one???
Also - is a remanufactured part reliable?
Old 05-17-2010, 05:05 PM
Timz06
Timz06's Avatar
Donna, I wouldn't recommend a rebuilt alternator for the track. I think it's better just to pay the money for a new one, rather than risk ruining your day if it fails.
Tim
Old 05-17-2010, 06:09 PM
ERND IT
ERND IT's Avatar
Cruise-In V Veteran
To Z06 throws Low Voltage code
Quick Reply: Z06 throws Low Voltage code
