>>LG Motorsports NEW Drop Spindles **IN STOCK**<<
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Hey guys,
Lou gave everyone a sneak peak this past fall, well now they are in stock and ready to ship!
LG Motorsports new forged drop spindle for C5/C6/C6Z Corvette.
A must have for lowered cars! Our new drop spindle will effectively lower your car slightly more than 1" from stock while leaving the control arms in the factory locations and within GM's designed suspension curve. We have been using these on all of our World Challenge Corvette's since 2004, and are currently being used on the new GrandAm GT #28 LG Motorsports Corvette
Our drop spindles include one full set of four uprights, assembled with mono ball upper mount, pivot pin, and nut. These are 100% direct replacements for your factory unit, with no modifications required to your factory control arms, bearings, tie rods, or caliper mounts.
Don't forget about our brake ducts and SKF bearings when doing the upgrade as well!
In stock, and ready to ship for only $2995 per set of four!
Call us today for your set!
$2995 FOR ALL FOUR!!
I have a quick question for you Anthony: Because these are drop spindles, does that mean there is more room between the bottom torx bolt holding the bearing assembly and the lower control arm ball joint nut? It would be really cool to be able to change bearing assemblies without splitting the lower ball joints.
Just curious....
Just curious....
I will give these a big +1, have seen them in person on the Grand Am car and they are quite a nice piece, for a great price
Former Vendor
Just curious....
Just curious....
Former Vendor
Just curious....
Just curious....
Effectively, we leave the upper and lower in the same location, and the bearing is moved upwards in the same real estate.
Its been a long time coming, as these used to be machined out of very large blocks of billet, costing upwards of 2000$ in material alone.
Now we have them forged, and then final machined. This cuts down on waste, and machine time as well as making the final price much much more cost effective. Previously, they were for mere immortals, costing 6,000$/set.
Im really excited about them
1 Post
What are the advantages of these over stock spindles?
In other words, what do they do to help a race car?....seems like a lot of $ to lower the car 1" when you can lower it via coilovers....
Sorry for the questions but there is really no info on your site to understand what they do
Former Vendor
camber curves, bumpsteer, bumpsteer curves, angle of the upper and lower control arm angles.
The corvette is designed to work 20mm~ lower than stock ride height. When you lower it past that, to get the CG down, and the car out of the air, the suspension geometry start getting a little crazy.
This allows us that bigger drop, with virtually zero trade off, not to mention, your shock lengths do not have to be so stubby now
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Hi,
The weight difference is almost the same and in fact our CnC Spindles are 4 ounces heavier but they are about 3 times stronger.
A stock spindle on a car with slicks will actually flex where ours will not.
So the advantage is not only the ability to lower the car without changing the geometry that was intended from GM but they also increase the strength and provide a stronger part.
We could not race a car without these and I put them on my street cars also so the factory geometry still does what it was intended to do.
The upper ball joint is also a spherical bearing that is teflon lined.
Again, we are really happy to be able to offer these at almost 1/2 price from the original spindles that we had built. Direct bolt up and a good looking part too. With the improved CNC program we were able to clean up the radius plus remove some unneeded weight.
Lou Gigliotti
Lou Gigliotti
__________________
LG Pro LT Headers, MOST HP, MOST TORQUE
http://lgmotorsports.com/gallery/alb...no_compare.jpg
LGM http://www.LGMotorsports.com
Winner Daytona 250
22 WC Wins
"Most powerful Corvette headers on the planet"
Winner Daytona 250
22 WC Wins
My car is at the low end of stock ride height and I scrape on lots of stuff, even at low speeds and taking inclines at an angle.
Andy
Former Vendor
These do look like a very nice piece and I understand the objectives in lowering the CG while maintaining proper geometry, but I don't see how you are able to run a street car this much lower w/o constantly replacing the splitter/dam.
Andy
Andy
The suspension geometry at that ride height leaves something to be desired for the track guys that want the suspension to live where it was designed by GM to be.
The next issue you are going to run into is shock length. Droop vs compression, and a happy medium between with healthy stroke on the shock to still do its job.
As you begin to lower the car, you quickly run out of shock travel. Go too short on the shocks, you run out of droop, and are forced to run the car at an aggressively low rideheight. Sometimes you need to raise or lower the car to help tune it. You cannot do that if you are out of shock travel.
Is it overkill for the street? Yes. however, some opt for them because they want the car lower than possible.
They are designed for the track enthusiast who wants the most out of their car. Theyve done coilovers, R compounds, good brakes, see a lot of track miles a year, and want to take the next step.
At the previous 6k$ pricetag, there was interest, but too many people walked away, saying they were too expensive.
When we realized there was a market for a cost effective solution, we looked into forgings, and realized it was a big initial investment, but well worth the cost in the long run when trying to take corvette performance to the next level.
Louis
Former Vendor
THANK YOU TO EVERYONE!
These have been a HUGE success and the first production run came and went very quickly. Almost within days of the trucking pulling in.
I have our new batch coming in early next week so I am ready to start shipping right after the 4th holiday. Get your orders in early before this one is gone!
Call us today to get a set ready to go today!
