wheel size question
Old 05-22-2010, 11:16 AM
Z06Tracker
Z06Tracker's Avatar
Default wheel size question
Can I run a 275 on an 8.5 inch wheel and a 295 on an 9.5 inch wheel without any issues?
Old 05-22-2010, 02:31 PM
thehammer69
thehammer69's Avatar
Not sure on the 275 for 8.5 but I know you can do the 295 on the 9.5. Just look at all the C5Z's running Super Stock at SCCA Nationals and you will see mostly 295 Hoosier A6's on OEM 17x9.5 front wheels.
Old 05-22-2010, 02:54 PM
Pumba
Support Corvetteforum!
Pumba's Avatar
Why do you want to run these tire sizes on such a narrow rim?
OEM Standard Rim Widths for these sizes are:
275 = 9.5 inches
295 = 10.5 inches
Old 05-22-2010, 04:08 PM
kmagvette
kmagvette's Avatar
The T1 guys run (or used to at least) 315s on 11" rears and 10" fronts. Even so, you would likely be better served running appropriate rubber for your wheels.
Worse case, you will pull in the sidewalls causing the tire shoulders to roll a bit.
Old 05-23-2010, 08:21 AM
Pylons
Pylons's Avatar
easily
Old 05-23-2010, 10:43 AM
Zenak
Terminal Vette Addict
Zenak's Avatar
basic rule of thumb is you can bump about 20mm on a tire over stock without issue.
After that it depends mostly on the tire, and the type of use.
Old 05-23-2010, 11:26 AM
Solofast
Solofast's Avatar
Depends on the tire brand, the section size (30, 35, or 40) and the diameter...
The Solstice guys are running 285 Hoosiers on 8.5 inch rims and it seems to work fine.
Old 05-23-2010, 11:44 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
tirerack.com has all the specs listed for different brands. If you have a tire and rim in hand I would feel good bumping one size in general. Aspect ratio plays a part as stated above.
Old 05-24-2010, 08:14 AM
Pylons
Pylons's Avatar
the 295 and 315 Hoosiers fit an 18x8.5 as well
Old 05-24-2010, 10:00 AM
drivinhard
drivinhard's Avatar
why in the world would you ever want to?
Old 05-24-2010, 11:08 AM
Pylons
Pylons's Avatar
sometimes for better grip, sometimes for more tire life
stock class autocrossers stuck with oem wheels sizes do lots of stuff that sounds crazy...but works
To wheel size question
Quick Reply: wheel size question
