Caging a C6 Z06
My car will be at DRM over the winter getting a full cage so I can run NASA/SCCA events next year.
Thanks. I was thinking around 8k. I know its a lot of labor given the aluminum frame - was curious what others have gone through. I Was going to put a 4 point in for the time being but it seems as though the bolt ins do not offer much more safety as compared to a harness bar.
When I spoke with Joe last year I thought he said about 12K. Maybe prices have come down. Tom, I looked into the Autopower cage as well.
Good luck Tom
Good luck Tom
here is a link to info on the Autopower cage. This was a prototype I think so I don't know how complete the finished kit is. Looks like you have to weld everything together yourself, and obviously bolt/gusset plates to the frame
http://www.ioportracing.com/rbc/05Co...vetteZ06-4.htm
Yikes! $12k for just a cage? I just had my C5Z caged for $3k (not including window nets, fire system, etc.). Cage is SCCA/NASA spec for T1 or ST2, etc. I think with a C6Z aluminum frame they have to sandwich the frame with steel plates and then weld the bars to the steel plates.
Z06-505 just had one custom built and installed in his Z06 by Joe Rook in cincinnati.
Absolute great job
PM him for details
Absolute great job
PM him for details
We can build you a cage legal for any sanctioning body in a c6 Z, all tig welded,full interior painted for 6k. Unfortunately, my cage is already tested with an airborne assault into a concrete wall at Rd Atl in march. I didn't get a scratch. Pics at www.vettesport.net
Jerry
Jerry
If you are referring to method of attachment it is briefly as follows. Steel Uchannel plates are fit to the frame at 6 points. These are then 3m epoxied and bolted entirely thru the frame with aluminum spacers to prevent crushing the frame. The cage is then welded to the channel. The front A pillar cage bar is bolted to the aluminum front vertical support bar on each side tying in the cage to the rigid aluminum support there. A full tube is run under the dash tying in the front A pillar cage bars. Car weighed post install with 185# driver 3100#. My cage has 1 3/4" .120 DOM tubing. You can use 1 5/8 .120 for SCCA.
Call or email for more specific info. Contact info is at www.vettesport.net
What is the cost break down for a 10 to 12K cage in a C6Z06
material?
Hourly rate?
Total hours?
Is the cage the same spec as used by the Corvette racing team "GT2"?
material?
Hourly rate?
Total hours?
